Question about Frigidaire FWS833A Top Load Washer
Wont spin my washer,fills an then does nothin..i'm not gettin any reaction
  • robert samples May 11, 2010
    try turning it to spin and tell me what it does
  • 57 Answers
Check the motor plug it might not be pluged in all the way or may have a bad connection in the plug
Posted on Feb 16, 2008
Start wash program, fills with water, then drum does not turn.. Tried rinse progam, water ,does not turn.. Can hear relays clicking but nothin moving. But the time carries on counting down. It does drain...
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
Oct 29, 2011 | Bosch Exxcel WFX 3267 Front Load Washer
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
The lights are coming on but nothin is happening what do i do ?
wahing machine must of filled but then stopped on wash wont spin or rinse lights all on any ideas
Mar 13, 2010 | Hotpoint Aquarius WF220 Front Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
No reaction
If you are not getting any noise whatsoever, you may have a defective lid switch or timer. If you hear a distinctive hum or buzz followed by a click and then no hum, the unit has a defective motor.
Feb 13, 2008 | Frigidaire FWS833A Top Load Washer
Washer fills up but wont spin
roof, if it fills and just sits there it could be the pressure switch, grab the end caps on each side of the consol and pull them off. Remove the two screws under them and flip the consol up. On the left side you will see the pressure switch with a rubber tube going to it. Get yourself a piece of tubing about the same size in diameter. After the washer fills, remove the tube from the pressure switch and blow into with the spare tubing. If the washer starts agitating, the pressure switch is the problem. Catriver.
Sep 29, 2007 | Kenmore 13202 Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
