Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Cannot make long distance calls
All of a sudden, we get an error when making a long distance call. Is there something that was possibly reset?
    Sniper:
  • 71 Answers
I can only think that you have 'least cost routing' or 'call-trunking' from somebody. Basically any number that is called will automatically be routed through a network other than BT - the main reason for this is to save money on calls (typically 15%)
If they have a problem with their server/trunking that would be the problem.
Plug a different telephone into the phone socket your fax is plugged into. If you can make a call long distance on it, the fax is at fault, if you can't contact your telelphone line provider and check the settings on your 'Least cost routing'.
Some LCR services are appalling.
Posted on Feb 14, 2008
How to Change COS (Class of Service) Password
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Mar 25, 2014 | Nortel Norstar M7310 Display Phone
I suddenly cannot make long distance phone calls
Sometimes there is a setting in the phone to allow only local calls, but if that is not the case, it may be, like a couple of times happened to me, that you have gotten "slammed". Carefully check your phone bill or call them to see if your services have been changed. This was a big problem for me a couple of years ago. Good Luck!
Oct 26, 2013 | Panasonic Lands Phones
Samsung mobile phone error codes 3d010017
my mobile phone SGH-U708E will shut down without any reason suddenly while making a phone call, it will show the error code"3D010017" after restart it.
Aug 06, 2009 | Samsung SGH-t219 Cellular Phone
Air conditioner not running properly
This is an Error code. Something shorted or fail to perform it's job, possibly a safety device found an error, and the system cannot function until fixed or possibly reset. I am unfamilar with this unit. Might try service technician, or if under warranty call dealer for tech support. Try unpluging unit for 5 minutes and then pluging back in...it may reset the trouble code and perform correctly this time.
May 17, 2009 | Haier ESA3125 Wall/Window Air Conditioner
Sudden toner outage
yes, error 74 points to toner empty. open front door, press "options" then "start" then "1" and "0". once shows accepted, close front door. make note of this as it very well may happen again.
hth,
razors
Mar 23, 2009 | Brother MFC-7820N All-In-One Laser Printer
When I try to fax there is a beeping sound. the report says the line is busy/noresponse
i would first reset up the machine in send and receive mode, is there dial tone. let me know what happens
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
I can't make long distance call?
Is this a recording, or does the phone display this ?
If this is a recording, it is from the long distance provider. Did you change long distance companies lately?
Call your long distance company....this is their fault.
Nov 13, 2008 | NorStar Meridian M7310 Phone
Zoom lens
What camera are you using is the lens making a noise when it stops focusing  call sigma imaging uk 01707 329999
Oct 19, 2007 | Sigma AF 28-200 Lens
Can't call long distance with new phone
Suggest you check with your phone company first. Many areas now require you to sign up for "long distant calling plan" before you can call "long distance".
Jul 15, 2007 | GE 25836 Cordless Phone
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
69 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
