Question about Garmin StreetPilot i3 GPS Receiver
How to bring up "via" command
How do I initiate the "via" command?
  • 1 more comment
  • hjl2 Feb 13, 2008
    I can't determine how to visit the "via" command.
  • hjl2 Feb 13, 2008
    Having a problem trying to locate the Via command
  • hjl2 Feb 17, 2008
    On my Garmin StreetpPilot i5 GPS the solution does not work. I have tried many times while attached via a USB connector on my laptop PC. Is something lost when after entering the last waypoint and entering Start Navigating, then back spacing to My Favorites again to select my first location? After reading the manual again perhaps I have to actually be driving the route rather than at home on my computer. Page 14 Quote: "Note: You can add only one via point at a time to your route. After you drive past a via point, you can add another point to your route". I would appreciate a more detailed sequence of events to make this work. Thank you. Harold Kelsey
    Novelist:
  • 113 Answers
Tell the GPS to go to the location you want to go to last. While that waypoint is active, pick the location you want to go to first. Since a waypoint is already active, a prompt should pop up asking you if you want to go to your final location via the new one. Click yes and the GPS will insert the new location into your route. You cannot have more than two destinations at a time.
Posted on Feb 15, 2008
Ok I have a moto G cell phone and I have a moto H300 bluetooth.. All I need to know is what voice commands do I use to work it
Darr-
You have to touch your phone or your headset to initiate voice search/commands. The Moto G doesn't have a voice search function enabled all the time that allows you to activate it completely with your voice via headset.
Mark
Motorola Headset
Feb 16, 2015 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Only rings 3 times then transfers to another ext.
Mitel call forwarding is a double-edged sword. It can be controlled by the end user via user-programmed forwarding and it can also be controlled by the system programmer via system call rerouting. User programmed forwarding OVERRIDES system programmed 1st alternate, but does not override the 2nd alternate reroute destination (if 1 is programmed). Try un-forwarding the phone - if still no joy then contact the system support person. Hope this helps. (User-programming commands are initially defined by the system support people when the system is initially installed, so I can't tell you how to do it... you'll need to know what the key commands are (or unforward using the Superkey function if provided).
Dec 13, 2013 | Mitel Lands Phones
How do I set time on a 4Gb Sansa Fuze?
Press the MENU button to bring up the main menu. "Turn" the command wheel to select "Settings" and press the central button. "Turn" the command wheel to select "System Settings" and press the central button. "Turn" the command wheel to select "Date & Time" (it's not initially on the screen, the screen will scroll when you hit the bottom) and press the central button.
Select the desired field by "turning" the command wheel and either press the central button or click the right side of the command wheel. Change the field by "turning" the command wheel. When you have the field set properly, click the left side of the command wheel and you can then select another field.
When done, repeatedly click the left side of the command wheel to back out of the menu system.
Apr 26, 2011 | Audio Players & Recorders
La Cie USB hard dirve its lighting intermittently red and yelow and the computer not recognized
Plug your usb drive into your computer. Then right click on my computer and select manage. Select disk management in the left pane. scroll down to look for your external drive in the bottom pane. You might need to initialize the disk by right clicking the gray area to the left of your disk on the bottom pane. If its already initialized you should be able to right click the disk just to the right of where you just clicked and select format, making sure to assign a drive letter and do a quick format of ntfs through the wizard that pops up. If the drive is labeled GPT protected you'll have to convert the disk to MBR by using the diskpart command. Go to start then run and type cmd and hit enter to bring up the command prompt.
  1. Type diskpart and hit enter
  2. Type list disk and hit enter and find your disk in the output
  3. Type select followed by your disk's number, for example "select disk 1"
  4. Type clean and hit enter
  5. Close the command prompt and now you should be able to initialize and format your disk.
Mar 04, 2011 | LaCie F.A. Porsche (301177) Hard Drive
Win 7 Ultimate will not recognize my LeCie big disk extreme back up drive. LaCie support was no help.
Mar 03, 2011 | LaCie Big Disk Extreme (300797U) 1000 GB...
Can,t get into existing router after moving home via 192.168.1.1 as suggested by internet provider
Download and install this program http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=mp-88884-1 on a computer that is operating on the network or is plugged into the router. Press start and then it will scan, when it finishes, click on Advanced Tools and look for your Default Gateway (your router's IP address) on the right+hand side of the screen
If that doesn't work try this on a computer that is plugged directly into the router, go to Start > Run and in the Run window type CMD to bring up command prompt. In Vista and Win 7 type CMD into the Search bar and then right click CMD and select "Run as Administrator" to open command prompt. In command prompt type IPCONFIG /ALL this will bring up a list off your connections, try to locate Default Gateway (that's your router) and then use THAT IP Address to connect.
Hope this helps!
Dec 16, 2010 | Linksys Computers & Internet
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS
Want to initiate symantec virus scan on remote via command line
If you are using Symantec's Corporate antivirus, you can initiate a scan using the System Center utility. The System Center utility can be installed from the main CD if you haven't already installed it. If it is a home version of Symantec Antivirus, I don't believe there is a command line option.
Hope this helps!
Apr 08, 2009 | Computers & Internet
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Garmin StreetPilot i3 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
