Question about Nokia 6630 Cellular Phone
Both charging points on pcb shows short.
I have one nokia 6630, shows not charging on the screen when i connect charger. when i checked its PCB i found both points where charging touches is showing shorting, i removed everything upto diode, but i am able to remove shorting on charging points
  • 4 more comments
  • deepak kumar
    deepak kumar Feb 14, 2008
    no phone is not short , if i use charged battry it works properly.but when i connect charger it says not charging on the PCB where charging socket touches on those points of charging it shows shorting.
  • Anonymous May 17, 2008
    there is no segnal when i make charge to nokia 6630 p.l.s find a solution to solve it
  • Anonymous Jun 13, 2008
    Yip me too, put on charger overnight and it wouldnt switch on. Bought a new battery and it worked fine until I put it on charge now all I get is blank, wont switch on. The battery was brand new so I cant understand it, it still wont charge, juust nothing.
  • keithski0806 Jun 13, 2008
    Phone would not aharge, so bought new battery. put new battery in charge one time, then that wouldnt work either. Phone dead.
  • drunbreakabl Nov 28, 2008
    i have the same problem my phone wont charge and when i replaced the battery with a full one itworked fine but not charging either. i opened the phone and the pins r fine and not short or anything and now i donno wat 2 do
  • Rustan  Garcia
    Rustan Garcia May 11, 2010
    does the phone is shorted?
    Guru:
  • 167 Answers
Try to change charging pin...
Posted on Feb 16, 2008
Display shows F3
Communication Wired R/C.
Cause of error
1. Open/Shorted
2. Wrong Connection
Check point, Normal condition
1. Connection of wire
2. Main PCB voilt: DC 12V
3. Noise Interference.
Check points:
1. Check the wire connection, Open/short, Repair the connection.
2. Check the soldering state of the connection ( Soldered Poorly ), Replace the PCB if so.
3. Check the volt of Main PCB power source. ( DC 12V, DC 5 V ) replace the PCB.
4. Check the installation of wired remote controller. ( Noise interference ) A just the state of the installation.
Apr 07, 2015 | Heating & Cooling
Nokia 6630 white screen
Hi, the fault suggests that the screen connector may have become dislodged from the main PCB
Dec 08, 2012 | Nokia 6630 Cellular Phone
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
OR:
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
My phones power stitch is not working
Dear customer
At first u just connect the charger of ur mobile and see its charging or not if it is showing charge then there is a problem in ur on/off switch or connection between CPU to switch. Change ur on/off switch or make the proper connection if u are a professionally trained for mobile repairing. If ur mobile phone doesn't charge after connecting the charger then its a hardwere or softwere problem in PCB (Printed circuite board). It is better to go at NOKIA care if u are not a Technician. Thank you for visit.
May 22, 2010 | Nokia 3110 Cellular Phone
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
Nintendo ds lite won't power up
Try two things.
  1. One of the LCD screens is making a short circuit. Disconnect them and see if the charge led turns on. If so, check these screens (or replace them)
  2. You could also have a defective Wireless PCB (the small PCB that has the black Wifi Cable connected). If that PCB is defective, loose or even missing, the DS Lite will do nothing at all
Nov 19, 2008 | Nintendo DS Lite Console
6630 "Not Charging"
my frind use corect batery that is Nokia BL-5c 3.7V made in hungary
Aug 17, 2008 | Nokia 6630 Cellular Phone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Nokia 6630 Cellular Phone Logo
144 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
