Question about Garmin eTrex Legend Cx GPS Receiver
Coordintates seem to ALWAYS be off by 20-50 feet
Ever since moving my GPS unit form Idaho to California the coordinates seem to bee off by 20-50 feet. I have turned on and off the WAAS and it has made no difference. I had this problem two times in Idaho but have it all the time now. In Idaho it seemed to be fixed by shutting off the WAAS. I have reset and reloaded and updated all software. Any suggestions would be usefull.
Thanks
    Novelist:
  • 113 Answers
How are you determining your error? If you are comparing your position to a map and you are getting error consistently, it could be that your map datum does not match the datum set in the GPS. Without WAAS turned on, your error should be @15'. With WAAS on it should be @ 6 to 9'. If you are using the Sattelite screen to determine your error, remember that is just estimated error. Higher estimated errors can be caused by satellites that are blocked or not visible to the GPS, or poor satellite geometry. It is normal for example, to have more error in high northern or southern latitudes due to less satellites being visible. With good reception you should be able to see 8 to 12 satellites on your satellite page. Signal strength is also important, You can have a lot of visible satellites but if the signal is weak your error wil increase. The signal can be weakened by heavy tree cover or high objects such as buildings or mountains. Such interference is called signal path error. Another form of signal path error is when the signal gets reflected off something before it gets to your GPS. For example; you're in a canyon and satellite 1 is to the east of you. The eastern rim of the canyon blocks the signal from satellite 1, however the signal bounces off the western rim and your GPS then picks it up. Because it took longer to get to your GPS, the GPS thinks that the satellite is farther away than it really is, causing a postion error. (This would not show up on your estimated position error shown on the satellite page because the GPS does not know this is happening.)
When WAAS is turned on it takes a channel that would normally be dedicated to a GPS satellite. It's possible that turning off WAAS helped you because having an extra GPS satellite improved your geometry which improved your accuracy more than the corrections WAAS is designed to make. The next time your error seems high, check how many satellites are being tracked and how strong the signal is.
Posted on Feb 15, 2008
On google plus it allows you to share your location with whom ever you choose, so my husband and I share our location with each other, but for some reason his is always wrong, and it always shows him in...
Hi Brenda
You need an App that will give you your current GPS coordinates.
Install an App Like MotionX or similar. Check the Latitude & Longitude or Better still the UTM Easting & Northing (same thing but UTM is the new digital coordinates & is easier)
Compare one phone coordinates with the other phone.
they should be almost identical if your in same location.
Otherwise check your phone SETTINGS for GPS & how it's set up.
Even a standard Garmin GPS tracker (which I use for prospecting) can be set fro the wrong side of the world. Usually its set for WGS 84 or 94 & UTM. I have seen people set up for the northern hemisphere when they are in the southern hemisphere.
Also, you said that your husbands settings never change. Well... it's GPS either turned off or broken.
I also use my "Find My Phone" App to check on the wife.... and she's on her way home... so GoodLuck
Cheers
Trevor
PS
Poor choice of Brands.... but thats another story.
Aug 06, 2014 | Cell Phones
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
How do i insert a coordinate to find a spesific fishing spot
The Garmin nuvi's were designed as automotive navigators and not really designed to be used as marine or outdoor GPS units with the exception of the nuvi 550 which is an all around GPS.
The Garmin handhelds are recommended for marine and off road recreational use but it is possible to navigate if you know the coordinates of your fishing spot.
To enter coordinates: Touch Where to? > Coordinates and touch a box to enter a coordinate.
You can also refer to the manual for more information. nüvi® 215
Sep 22, 2011 | Garmin nuvi 215 GPS Receiver
We are going to Europe and using Camping Cheques Brochure but the GPS Coordinates are as such L49degrees 0'10"1:2degrees56'28" but my Garmin Sat Nav Coordinates only give me a choice of N,S,E,or W can you...
I would suggest that you go to a web site that will take those co-ordinates that you have, enter them and then get or have the program show you the other co-ordinates that you need and can use, Also you may want to check in the sub menu on the gps unit, sometimes some of them have the ability to switch to different co-ordinate system, but this is sometimes, not always. Hope this helps
May 10, 2010 | Garmin nuvi 255W GPS Receiver
I have a Magellan 4350. From day one, my home
if you havent installed the latest v8.3.2.64084 update go HERE and download it and follow the directions carefully.
bill
Jan 01, 2010 | Magellan Maestro 4350 GPS Receiver
Why is my coordinates off by 50-80ft. why? Side by side comparision of another gps shows my gps is not accurate.What do I do?
Your GPS is accurate for that brand. I have a Lowrance I Finder Pro. We could both put in the same coordinates and come up in different locations. It is just the way the different GPS's get their signal from the satellite. I use my GPS most of the time for a sport called Geocaching and so when I am given coordinates and don't find the thing I am looking for I so about a 30ft-60ft search around where my GPS took me. So yours is basically doing the same thing. I wouldn't worry about it......it's just the way the different models receive the signal that thows them off a bit. If you went out and got a set of coordinates and then I put those same coords into my GPS I would arrive at a completely different location as you. All is well....no need to worry.
Aug 07, 2009 | Garmin eTrex Legend Cx GPS Receiver
Garmin always 1/2 mile left of actual position
it could be the unit or the film on the windows of your car .... most of the time it is the unit messing up i have ran into this problem a few times installing
Aug 18, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin GPS 45
Switch-on while holding the MARK key, this performs a master reset and re-enter an initial position then leave it receive in full view of the sky (outside). This only needs to be done once, but deletes all user data.
The GPS can take 30 to 45 minutes to acquire.
It worked for me on GPS 45, twice.
Apr 13, 2008 | GPS
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Converting GPS coordinated to google earth coordinates
Feb 10, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend Cx GPS Receiver Logo
150 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
