Question about Samsung SyncMaster 740N 17" LCD Monitor
Screen inversion yesterday the computer dinged as when the monitor starts up (everything was already running all day) then the screen inverted, mouse inverted, etc. Everything on the screen runs fine, but upside down. ???
  • doc2th Mar 15, 2008
    control+alt+ up arrow
    solution:
    cont+alt+up arrow
    this will flip the screen.
    cont+alt+down arrow will invert the screen. this is so you can mount the monitor upside down if you want.
  • 20 Answers
There will b a auto button on ur monitor.. press it n c whther the problem is solved or nt.....
Posted on Feb 13, 2008
My monitor started going black yesterday.
Check the power cable if its connected. Otherwise your monitor it maybe broken
May 04, 2011 | HP w1907 LCD Monitor
Just a few days ago my laptop was working perfectly fine then all of the sudden it had a smoky smell and the screen went black. I turned it off and waited a little bit and turned it back on. It starts up...
Where there's smoke, something burns. It sounds like the monitor or video cards has/is going out. First I'd have you contact the tech support for your computer and find out what options they have for you. To replace the monitor is not that hard to do, but you do have to have the correct parts, again from the manufacturer.
I would say you will either need to send it back or just hook up an external monitor and keyboard/mouse.
Apr 07, 2011 | Computers & Internet
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Monitor Turns Black
Hi
you have cold solder to PCB and you have to resolder the Cold solder to PCB
Thanks!
Jul 03, 2009 | Computers & Internet
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
Gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Apr 03, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Compaq NX7010 Display problem
Sounds like either the LCD or the inverter to the LCD is going bad you on. After it heats up thats when the problem starts. If your laptop is under warranty I would call HP Tech Support and let them troubleshoot with you over the phone either way they will probably replace the LCD and inverter.
Feb 28, 2009 | Compaq Computers & Internet
Samsung SyncMaster 740N 17" LCD Monitor Logo
65 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
