Question about Lexmark X4270 All-In-One InkJet Printer
Error 1203 i have a lexmark all in one x4270 and it has a error code 1203 can you help me with it?
Are you using a refilled cartridgeerror 1203 - 1.gif or refilling your cartridge yourself?
Error 1203 is an issue that occurs either when a cartridge is bad or the printer1.gif cartridge Slot is bad... Try to cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work, then you might try a new black cartridge and possibly a color cartridge too.
Hope this helps.
Good luck.
Mac
Please remember to post a feedback and or rating if my suggestion has helped you fix your problem.
Note: Refilling carts may damage the contacts of the carts as well as the printer (From a printer companies website)
(repeating this message again, for some reason this site logged me off and It didn't give me credit for the post)
Mac =)
Posted on Feb 13, 2008
Are you using a refilled cartridge or refilling your cartridge yourself?
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... Try to cleaning the copper contacts of the both carts and cart slot in the printer and try again..
Hope this helps.
Good luck.
Mac
4 Suggested Answers
SOURCE: error#1203
I had the same problem, and I took the advice to clean my printer heads...All i done was take out both, color and black ink cartridges, wiped them with a dry towel very softly, and reinserted them. It came up with 2 messages to confirm the colors item number, i pressed select like 6 times, then it printed an alignment page...I was good to go from there! Good luck to others!
Posted on Sep 03, 2008
pineworks
  • 4041 Answers
SOURCE: What is Error #1203 on the Lexmark X4270 fax
Hi there
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Posted on Apr 26, 2010
Daniel S
  • 4323 Answers
SOURCE: Lexmark x4270- Can't find manual. Shows error
Hi
Error 1203 occurs due to smearing of ink on the carriage bottom where the cartridge head touches the carriage bottom. Please turn off your printer and unplug it.
Clean the bottom of carriage with a damp cloth and clean any dried ink. Make sure that you use the printer after 5-10 mins or until the carriage area dries up completely.
If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
Now try and check whether you are still getting an error. I hope that you are using orignal Lexmark ink. If not then please use genuine inks only.
Daniel Scott
Posted on Jun 10, 2010
I want to print the letter . on the machine's screen i saw error #1203. it wrote consult user guide . could you tell me how to slove the problem
1203 error indicates a communication problem with your printer and one of your cartridges. Please refer to this article in the Lexmark website: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. This will help you identify and resolve the 1203 error message on your printer.
Apr 21, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have an error message #1203. What do I need to do?
The 1203 error indicates a problem in either one of your cartridges or between one of the cartridges and the printer. This article will help you determine the cause of the problem and how to resolve it: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers.
Apr 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
THE DISPLAY SCREEN IS SHOWING ERROR #1203
The 1203 error indicates there is a problem with one of the cartridges. You may refer to this article to determine the cause of the problem and find a resolution: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers.
Apr 04, 2011 | Lexmark X4270 All-In-One InkJet Printer
I keep on getting error # 1203 what does this mean?
Error 1203 indicates a problem with one of your cartridges. Refer to this article from the Lexmark website on How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4270 All-In-One InkJet Printer
Ive a lexmark x4270 tried to copy says consult user guide for error #1203 and i dont have a users guide. anyone know what i need?
The error #1203 on the Lexmark X4270 indicates a problem with one of the ink cartridges. You can try to check this link - http://bit.ly/ckmSbC - for the steps that will help you resolve the problem. If it still the small I would suggest contacting Lexmark Technical Support. Thanks.
Aug 08, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270- Can't find manual. Shows error 1203. How can I correct this. Thanks
Hi
Daniel Scott
Jun 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Need UsersGuide for Lexmark X4270, ?code 1203? on LCD panel!
cant find a user manual, only install manuals :(
from reading on your error it seems to point to an ink cartridge issue have a read of some of the following links
http://www.fixyourownprinter.com/forums/printer/38960
http://www.fixya.com/support/t131154-error_1203
loads more, just search lexmark x4270 error 1203
May 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 error code#1203 want print
Please visit this below mentioned link to solve your problem:
Error Code 1203
Thank you
Dec 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270
This may be due to communication issue. Below link may be able to help you to resolve this issue..
http://etech.maiila.com/lexmark-x4270-driver-software-download-including-for-vista
Nov 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
