Question about Toastmaster 6202 Popcorn Maker
Uncooked popcorn popping out all over the place
I am experiencing a frustrating problem when I try to make popcorn with the Toastmaster 6202 popcorn maker. A lot of the uncooked popcorn, and I mean a lot, is being ejected out of the popper with the actual cooked popcorn. Is there a replacement part or something that can be retrofitted to stop this? Thank you for your time...John
jwhitcombe@rogers.com
Tilt it backwards some. I had this problem with a presto. It's tricky but I propped it up in the front with something small and leaned it back against kitchen wall.
Posted on Mar 20, 2008
Elite Epm250 Popcorn Maker instructions
Turn on the heater and let heat for 2-3 minutes. The Elite EPM 250 popcorn maker uses a 2.5 oz kettle. This is for 1/3 cup of uncooked kernels. Add kernels with a tablespoon of popcorn oil (available in markets) and a 1/3 teaspoon of what's called "Flavacol". It's a seasoning that they use in movie theaters to add flavor, saltiness and color. It's available online (ebay) or at Smart and Final. Use this combo and you can't go wrong. For cleaning, let kettle cool, the add 1/2 cup water. Turn on kettle and let boil for 2-3 minutes. Then empty it out.
Jan 15, 2012 | Elite Epm250 Popcorn Maker
Can you use this machine with oil and salt
NO. There should be a little cup / scoop on top of the lid. This is used for measuring the popcorn and then melting butter to pour over it when it's done poping. Then you can add salt to the popcorn.
Dec 28, 2010 | Toastmaster 6203 Popcorn Maker
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
Jun 27, 2010 | Kitchen Appliances - Others
The popper is only popping 1/4 of the cernals!
There are a few things that you may experiencing issues with on your unit. Please contact Nostalgia Products at 1-920-347-9122 and they can help you figure it out.
May 19, 2010 | Nostalgia Electrics CCP-509 Popcorn Maker
Half the Kernals spit out uncooked
It coud be 2 things. Either a low grade of popping corn, or old popping corn. Hot air poppers blow the same temperature, until you shut them off. Although the better grades of popping corn cost a good amount more, you don't throw half of it away. Once the popping corn container has been opened, you should use it up within about 3 months. The internal moisture content is what determines whether corn will pop or not. Too much or too little moisture will not allow the corn to pop.
Aug 23, 2009 | Toastess Hot-Air Corn Popper Popcorn Maker
How much oil and popcorn do you need in the popper
single layer of popcorn on bottom of entire maker...no oil is needed but you can use a tablespoon if you like...butter melts through the hokes in lid....Place butter pats over top holes in lid before popping starts if you want butter to drip down on the corn ( it does pop better with a little oil!)
Dec 09, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Nov 06, 2008 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Directions for use.
Hello guencat. Send me Mgf. & model and I will find an answer for you.
Oct 12, 2008 | Toastmaster TPC2 Popcorn Maker
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Kettle Keeps jolting out of place
Popcorn popper is approximately three weeks old and now the popcorn clogs up in the hopper (cooker pot), the gear quits turning, and we have to pry the popcorn out. It worked perfectly when we first got it and now it is nothing but a pain to use. We tried several popcorns, cooking oils and amounts of oils, but the problem continues. I noticed the small spring located on the lower shaft doesn't cover the entire shaft. Is it supposed to be longer? Your prompt reply for a solution would be greatly appreciated or we will have to return the unit to our local retailer where we purchased it.
Aug 05, 2007 | Nostalgia Electrics CCP-509 Popcorn Maker
Toastmaster 6202 Popcorn Maker Logo
119 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
