Question about Singer 14SH654
Singer > Sewing Machines >
I had bent the needle and since then it doesnt stitch. I'm assuming the timing is off. if so do you know of a book on setting it. Thanks Bob
  • threads Apr 20, 2008
    I have a singer pro finish serger.  I bent a needle and it will not stitch anymore.  I just bought this machine and have never used a serger before. This is really holding back my work.  Please Help!
    Sergeant:
    Champion:
  • 240 Answers
Theres no books as such on setting the timing-it is something only to be attempted by an engineer. I take it you have replaced the bent needle, cleaned out any debris and checked the other needles for damage too. Also check it isnt hitting the needleplate which may now be scarred. Check needle is inserted correct way around.
Posted on Jun 13, 2009
The thread is stitched from the top only in singer 8280.
Try a brand new needle. A bent, damaged needle will sometimes not stitch correctly. If that doesn't work, most likely the machine has been knocked out of time. Take it for service.
Jun 20, 2018 | Singer Sewing Machines
My singer model 2263 will sew fine then it skips about 3 or 4 stitches. What causes this
needle /hook timing , incorrect needle thread tension or worn bobbin shaft
Mar 29, 2018 | Singer Sewing Machines
My singer tradition 2250 won't stitch without dropping stitchs worse in zigzags or with Lycra, have tried dog foot also. Have tried altering tension makes it worse, you can hear it skipping stitches.
Have you tried a brand-new needle? Frequently, a bent, dull, or incorrect needle will cause skipped stitches.
Also, for sewing knits (lycra), be sure to use a ball-point needle. Likewise, use the appropriate needle for the thread & fabric you are sewing. Avoid using old or bargain bin threads.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjawNi-zMvMAhUY52MKHbxmBzgQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
If it continues to be a problem, you may need to have it serviced for needle/hook timing.
May 08, 2016 | Singer Sewing Machines
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
Jan 04, 2013 | Sewing Machines
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
I have a Singer 367 and it will not do a zigzag stitch. The needle goes from side to side but I end up with 4/5 straight stitches and then 2 zigzags then back to 4/5 straight stitches. The tension and...
Either you have a blunt or bent needle or the needle is in the wrong way round or failing that you may need to retime the machine which is quite likely, if you email me I can attach instructions kendourof@yahoo.com
Aug 30, 2011 | Singer Sewing Machines
When the needle comes down in it hitting the metal cylinder that the bobbin sits on. The diagram in the instruction book doesn't show me how it's supposed to go, my model is a singer inspiration 4206, in...
You may just have a bent needle or a burr on your needle plate. Is the machine set to a straight stitch? If, not do so. Check these first. I doubt that it is the timing.
Sep 07, 2010 | Singer Inspiration 4206
Bobbin won't pick up stitch(thread)
Try a new needle, confirm needle is inserted correctly, needle flat side to back of machine. If still not needs timing, take to sewing machine tech.
Jan 08, 2010 | Singer 7422
Singer 14SH654 Logo
98 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
