Question about Fahrenheat F2543 Baseboard Heater
Parts for Fahrenheat F2543 baseboard heater
Can you tell me where I can get parts for my Fahrenheat F2543 heater. I need the plastic part that holds the heating element in the frame. Thank you.
Go to Home Depot, buy a new one, take the part you need, return the rest...
Posted on Oct 12, 2008
You might try www.fahrehheatpro.com, we manufacturer's website. you'll have to call them.
Posted on Sep 23, 2008
We installed fahrenheat f2546nwc baseboard heat and when we turn it on it smells like something is burning, maybe plastic. we have a honeywell thermastat , not sure how to tell if its double pole or if...
Sounds like possibly you haven't removed all packing material. All machines will produce a strange odor upon start up but should go away rather quickly. Be sure to Read the manual in it's entirety
Aug 02, 2017 | Fahrenheat F2543 Baseboard Heater
Parts for Fahrenheat lfp6152e
Contact supplier Marley @ 1-800-642-4328
Dec 29, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Where can i purchase switch for farhenheat baseboard heater?
remove the switch and contact either Grainger's or Johnstones and they will cross reference the switch.
Oct 05, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
What Size Circuit Breaker
a 750 watt heater at 240 volts draws 3.15 amps so a 2 pole 15 breaker with 14/2 wire would be fine
Nov 11, 2007 | Fahrenheat Electric Convector Baseboard...
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat F2543 Baseboard Heater Logo
298 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
