Question about Cameras
Vupoint underwater camera -fuzzy pictures
Is there a setting I can use to stop my pictures from blurring. Every picture I take is blurry.
Please help - I want to take this camera on a trip. All of the reviews were great for this camera???
VuPoint DC-WPC-ST531T-VP 5 MegaPixel Underwater Digital Camera (DC-WPC-ST531T-VP)
Thank you
  • kerrielynn Feb 14, 2008
    Thank you - I was afraid that there might not be a fix. I appreciate your response.
  • sexxiiboo23 May 12, 2008
    my camera is blurry and it has like blurry lines how can i fix it
My girlfirend just got me this camera and I've noticed that it takes fine pictures when the lighting is good. Under low light (i.e. underwater or in the dark) it's not so hot. I don't think there is a fix for that.
Posted on Feb 14, 2008
Make sure that the camera is not in macro mode. If you look at the camera as you would when taking a photo, there is a switch on the left side that should be in the down position.If it's in the up position, then it can shoot closeups only. This worked for a Vupoint 5 megapixel model DC-WPC. Hope this helps
Posted on Jul 27, 2009
Use the flash maybe???
Posted on Jul 30, 2008
How can i adjust settings for blurred pictures on Samsung ES15
That would depend on why the pictures are blurry.
If the pictures are blurred because of camera motion, you need to either use a faster shutter speed or place the camera on a tripod or other stable support.
If the pictures are blurred because the subject is moving, you need to use a faster shutter speed.
If the pictures are blurred because it's out of focus, you need to ensure that the camera is focusing on what you consider to be the subject, not what the camera chooses.
Aug 19, 2013 | Samsung SL30/ ES15 Digital Camera
Fuzzy with double picture
TV is blurry as if expanded, do not know how this happened. Words are blurred, picture is not crisp anymore. Help please.
Aug 12, 2010 | Philips Magnavox 27MS343S 27" TV
Lack of definition, blurriness.
Experiment with lowering the "exposure compensation" setting until you get the desired results. Also, don't forget to use a tripod.
Jul 15, 2010 | Nikon Coolpix L110 Digital Camera
Monitor for the Canon Powershot A75 is blurry.the pictures taken previously are fine that are on the memory card.
you say previous pics are ok Just the newer ones. Only a guess but it happens regularly... Makes sure you have not set the camera to MACRO mode as if its not aq close up then a;ll pics will be fuzzy and blurred.
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | Canon PowerShot A75 Digital Camera
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
White balance and blur underwater
You are not doing anything wrong with your white balance, white balance is very difficult under water, and you should be careful, because your mask might be tinted a certain color, I reccommend leving you white balance normal, then adjusting in photoshop, take a white object down there and hold it over a non important part of the picture, to help with adjusting in photoshop, then crop the object out of the final image. Focusing underwater is difficut as well, as dater distorts light, there is nothing that you can do to keep the water from distorting the light, but if you go to apeture priorities, you can increase your apeture to between f7.2 and f11 to reduce blur (to keep the picture from being too dark and the shutter from being too slow, you can increade your ISO)
Jul 28, 2009 | Fuji FinePix F100fd Digital Camera
Fuzzy pictures with the ge E1030
Did you change any settings ie. exposure value, shutter speed? Those could cause blurry pictures if you do not have the camera on a tripod.
Dec 27, 2008 | GE E1030 Digital Camera
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
When Zooming picture it produces blurred or fuzzy picture
This is when zooming through your camera LCD I presume? For small screens usually banding and pixelation is common, if this happens also when the picture is zoomed in on a larger monitor like on your computer then the resolution you set for your camera is low. You can check for the camera setting and increase the resolution from for example 1024x768 to a much higher value and the fuzinnes (blur) will disappear altogether...
Feb 08, 2008 | Fuji FinePix F460 Digital Camera
Blurry pictures in Sports Mode
Well, Sports Mode is a fully automated mode, which I believe tries to balance the exposure toward faster shutter speeds. An over all dark photo indicates an underexposure. You can adjust for underexposure by dialing in a 1/2 stop or so on your exposure compensation dial.
However, dark AND blurry indicates that you just didn't have enough light. The first thing you want, for that same shooting situation, is some faster film. Go up at least an f-stop or two (eg, if you're shooting with ISO 100 film, try ISO 400).
Pay attention to the shutter speed the camera is setting. If you're stilling still, photographing action, you'll want a pretty fast shutter speed, or you WILL get blurring. I'd recommend at least 1/250th second, faster still if you're trying to freeze motion.
A more advanced technique is to pan with your subject. Follow the subject with the camera, and use a medium to medium fast shutter speed (1/60th-1/250th). You will get some blurring, but if you learn this well, your subject will be pretty clear, and the background will blur... thus including the suggestion of speed in the final photo, rather than something that looks frozen. That can deliver a much more satisfying shot.
I have used Canons for years, but I avoid all of the those special modes, like sports modes. They're really trying to deliver some help, but these are techniques you should learn in any basic photography course.
If you set the camera to Av mode, you can choose the widest aperture available for that lens, which will always get you the fastest possible shutter speed -- thus, the least chance of blurring. If you still blur, you need more light, a lower f-stop number, or faster film.. those are the only cures.
Nov 29, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Cameras Logo
130 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
