Question about Olympus Stylus 700 / 700 Digital Camera
Olympus stylus 700 all weather
Hi
When the power button is pressed ,the lense cover starts to open and closes
again straight away ?? help I have photos to download from xmas and I need the cover to open
regards
Donna
  • 3 more comments
  • jr001w4796 Jun 22, 2008
    same problem as you but the camera makes a whirring noise and then on screen comes 5f 08 and 5e02 which i presume is an error mess i took to the camera shop and he didnt seem to think it was the battery
  • dewalker Jul 19, 2008
    when powered on lense start moving in and out, then blue screen with error 5f08
    5e02
    getting blue screen error 5f08 & 5e02
  • pushpita Aug 16, 2008
    hi,
    I too am facing the same problem as of Donna & jr001w4796.The cam makes a sound when I turn it on n then the screen turns out blue showing 5e02 error.Tried showing to a cam centre but they say that there isa problem witht he LCD itself...Please help to fix the problem...Also please tell me if there is any Olympus service centre in India( Mumbai).
    Regards,
    Pushpita
  • Anonymous Apr 22, 2009
    I have a similar problem as donna, i thought it was to do with the battery, however that was a wrong guess. I hope i can have this repaired.
La solucion esta muy sencilla....
lo que pasa es que la lente se trabo a lo mejor por un movimiento brusco o se te cayo...
entonces se desacomodan los engranes de la lente,,...
lo unico que debes de hacer es ..
PUCHALE EL BOTON DE POWER ,LUEGO CUANDO SE INCIA Y CIERRA LA LENTE Y APAREZCA LA LENTE AZUL, DALE MOVIMIETOS CIRCULARES Y HORIZONTALES O EN TODAS DIRECCIONES ... REPITES ESTO VARIAS VECES HASTA QUE INICIA NORMALMENTE YA ASUNTO ARREGLADO..SE ACOMODA DE NUEVO LA LENTE Y LA CAMARA FUNCIONA CORRECTAMENTE...
si no te funciona hazlo las veces necesarias tampoco excedas en movimientos, procura que no sean tan bruscos... puede salir peor..
nota::
el problema no se arregla con actualizacion de software---solo perderas tiempo... pork este es un problema fisico...
espero te sirva la info,...
pitufo
Posted on Apr 27, 2009
Address of authorised olympus showroom in mumbai:
Camera Care Centre
225, Commissiriat Bldg. Next to Old Hendloom House, Dr. D.N. Road, Mumbai 400001 India
Tel :(91) 22-2261 1274 / (91) 22-2261 4015
Posted on Oct 22, 2008
  • 4 Answers
Have you checked the battery. If you have charged it then it may be a bad battery. also if you are in a cold climate try putting the battery in your pocket for a little while. This is what the manual has to say.
Hope I have been of help.
Posted on Apr 17, 2008
I can't turn my camera on,I press the power button,it gives me a whirling noise,the lenses come out(but not all the way),the picture on the screen is blurry,and I can't make a shot,and after2 seconds the...
sounds like it might have got a bang,you'll have to take it to the shop,make sure you get a quote before you get any repairs done,camera repairs can be expensive.
Mar 18, 2010 | Olympus Stylus 700 / 700 Digital Camera
The camera may be faulty or it needs to be reset to the factory settings.
Try removing the battery leave it out for at least 1/2 hour, then replace the battery.
If it doesn't work then you need a new camera.
Nov 27, 2008 | Olympus Stylus 700 / 700 Digital Camera
OLYMPUS STYLUS 740 ALL WEATHER
If it works, use it as long as you can.
Fixing snap-shooters is generally not worth it,
since digital cameras evolve rapidly and lose
value even faster with age.
Martin
Nov 09, 2008 | Olympus Stylus 700 / 700 Digital Camera
My camera an olympus stylus 700 all-weather 7.1 megapixel, isn't turning on. When the on button is pressed the zoom comes out/in/out making a grinding sound, the screen shows a none focused image until a...
If the camera is still under warranty then return it.
If it is out of warranty then replace it
There is not a likely repair option
Though Olympus Customer support may advise another remedy
Jul 30, 2008 | Cameras
Olympus 700 problem
You have physically bent the lens extension mechanism.
Professional repair is required. Get an estimate first
to make sure its worth it.
The data on the memory card would not be effected
by such an accident, but copy it to a PC ASAP just
to be sure.
Martin
Jun 04, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus 700 all-weather 7.1 mp
Try turning to the guide and it will change the settings for you, as you step through the settings it offers.
Very smart camera!
Mar 16, 2008 | Olympus Stylus 700 / 700 Digital Camera
No sound when making video clips
Yes there is an option to turn the sound off, so you can take up less space on the memory card. Try turning to the video clips on the dial then push the menu button for options!
Nov 05, 2007 | Olympus Stylus 700 / 700 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
I have an error messag D: 5f08 5e02 on my screen.
D:
5f08
5e02 THIS FIX WORKS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BY TRIAL AND ERROR I FIXED MY mju 700 SHOWING THE ABOVE ERROR
IF YOU PRESS AND HOLD THE ok/function BUTTON, AND TURN THE CAMERA ON AND OFF A FEW TIMES WHILST KEEPING THIS BUTTON DEPRESSED, IT SHOULD HOPEFULLY SORT ITSELF OUT?!
(NOT SURE IF IT MAKES A DIFFERENCE BUT MY DIAL WAS SET TO scn FOUND INBETWEEN guide & the wobbly hand.
I ONLY TURNED on/off/on AND IT FIXED THE ERROR, IT MAY TAKE MORE FOR YOU.....I'M NOT SURE AS MINE IS NOW FIXED!
IT WORKED FOR ME, HOPE THIS HELPS, GOOD LUCK!
Mike
May 08, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 700 / 700 Digital Camera Logo
1,973 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
