Question about ViewSonic VX924 19" LCD Monitor
The monitor goes blank after just a few seconds or sometimes works for hours.
I have a KDS Model 700P, Product # K717S which is about 1 year old. It works fine sometimes for hours and other times the screen will look a little dark and then go blank after just a few seconds. Shutting off and then on again makes it work for about 1 second before going blank again.
mine is on for a sec, then goes black. I turn the power off and back on,,, the screen apears then goes black again.
  • 286 Answers
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supplyor other boards look domed or vented on the top.
Replace any capacitors accordingly. Monitor should work fine after that.
If not try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistora go bad. Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting the panel lights.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There's usually two light fixtures each of which holds two lamps. One fixture at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Posted on Feb 14, 2008
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 11, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Please see the following link
many available for fairly cheap prices
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Can my KDS (#K717S-700P) monitor be wall mounted?
This monitor can be wall mounted but I do not know what bracket you would use.
If you look on the back of the monitor you should see 4 indents in the sticker near the corners. If you don't then rub around near the corners of the sticker. With a sharp knife or pin you should be able to lift out these tiny stickers. You need to measure the distance between these on the horizontal, vertical and diagonal then you should be able to ask somebody at your local TV dealer for help locating the correct bracket.
I'm sorry i can't be more helpful.
Nov 24, 2008 | KDS K717s 17" LCD Monitor
This is a common problem across many monitors, unfortunately. The problem stems from one of two things, typically.
Itis either the Power Inverter board (Inverter Mirage Electronics AD-1700Rev:F 200-000-170DTL1 VERSION:A) or a weak or dying backlight.
Ifyour monitor comes on for a few seconds then you can test the backlight byusing the controls to get into the backlight brightnes settings on theOSD and turning it WAY down.
If that doesn't work or if it won't come on at all then it islikely bad capacitors on the Power board mentioned above. If you feeladventurous and know how to solder then you might be able to fix thisyourself. You need to be careful however because you are dealing withhigh voltage in there and capacitors CAN hold a charge long after youhave unplugged the unit. You can read more about this power board aswell as how to replace the bad caps HERE.
Ifthat's not for you then I would recommend taking it to a local TV shopfor them to fix. The parts shouldn't be more than $20, but labor can beexpensive.
Jul 30, 2008 | KDS K717s 17" LCD Monitor
KDS K717s = Radius-73 Model 700P
Most are snapped at the corners and center of each side.  A plastic ipod pry tool will usually get the process started, and you just work your way around the frame.  Starting at one corner is best.
May 27, 2008 | Gateway FPD2275W LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
123 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
