Question about HP OfficeJet t45 All-In-One InkJet Printer
Issue with HpT45 on start up
When I start up my computer... I get this box that always says Configuration in Process and it is like testing or looking for the printer all in one. How do I get rid of that box?
  • Anonymous Feb 29, 2008
    Time out, Never finish to initialize, problems since Oct '07.
    Upgrade or change driver NEVER WORK or WAISTING TIME..
    Hp only care to SELL you the new printer.
    Where is the FREE help/assistance ???
    Problem Solver:
  • 5 Answers
Read my other post for instructions.
Posted on Mar 30, 2008
I have an HP 3210 printer and Windows XP. Whenever I start my PC I get a message from Document Viewer asking me to install it from a removable disk. I can't find the disk.
Diagnostic startupDiagnostic startup enables Windows to determine the basic device drivers and software to load when you start Windows. When you use this method, the system temporarily disables Microsoft services such as Networking, Plug and Play, Event Logging, and Error Reporting. Also, you permanently delete all restore points for the System Restore utility.
Note Do not use this method if you want to save your restore points for System Restore or if you must use a Microsoft service to test a problem.
To perform a diagnostic startup, follow these steps:
  1. Click Start, click Run, type msconfig, and then click OK.
  2. On the General tab, click Diagnostic Startup, and then click OK.
  3. Restart your computer.
If the problem does not occur, use Selective startup mode to try to find the problem by turning individual services and startup programs on or off. Selective startupSelective startup enables you to select the files and the settings that you want the computer to load when you restart the computer. Select from the following options:
  • Process System.ini File
  • Process Win.ini file
  • Load System Services
  • Load Startup Items
By default, no options are selected. The following actions apply to these options:
  • When you select the check box, the configuration file is processed when you restart the computer.
  • When you clear the check box, the configuration file is not processed when you restart the computer.
  • When the check box is selected, and you cannot select the check box because it appears dimmed, some items are still loading from that configuration file when you restart the computer.
  • When the check box is not selected, and you cannot select the check box because it appears dimmed, the configuration file is not present on the computer.
  • You cannot change the Use Original BOOT.INI option button.
Note When you clear the Load System Services check box, you disable Microsoft services such as Networking, Plug and Play, Event Logging, and Error Reporting. You also permanently delete all restore points for the System Restore utility. Do not clear this check box if you want to keep your restore points for System Restore, or if you have to use a Microsoft service to test a problem.
To perform a selective startup, follow these steps:
  2. On the General tab, click Selective Startup.
  3. Select or clear the available settings.
  4. Click OK.
  5. Restart your computer.
  6. Repeat steps 1 through 5 until you find the problem.
Nov 04, 2010 | HP Photosmart 3210 All-In-One InkJet...
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
On my pc not any icon or start menu can be shown only wallpaper can be here
To solve this issue..
1) Click CTRL+ ALT + DEL at a time..
2) You will find Task manager option..
3) From that select process tab..
4) Then select explorer.exe...  And select end process..
5) Then select application tab...
6) And click o new task..
7) In the bar type explorer.exe..
8) Then select ok..
Now the icons will be reloaded.
Jan 02, 2010 | Microsoft Windows XP Professional
Run dll32 stopped working. Cannot access software with mouse.
Please follow these instructions to check which software is causing this issue:
1. Click on Pearl (Start Button), in the serach box type:
msconfig
and hit the enter key on the keyboard. It should open the System Configuration Utility window.
2. Click on Services over the top and then at the bottom right corner, put a check in the "Hide all Microsoft services" checkbox.
3. Click on "Disable All" button.
4. Click on "Startup" tab, and then click on "Disable All" button again.
5. Press OK button and then "Restart" button on the following window. Let the computer restart.
6. Once you're back on the desktop, you'd get a window for System Configuration Utility. Put a check in the box "Don't Show....." and then press OK button.
7. Now, once again check the issue. If the issue is resolved, open System Configuration Windows again and then enable all the services from Services tab and then check the issue after restarting the computer in the same way as mentioned above.
8. If issue is still resolved, enable half of the Startup items from Startup tab and then check issue.
9. If issue occurs again, it means, there's a culprit in the checked startup items. But if issue doesn't occur, then issue could be with rest of the Startup items. Now, uncheck the first half startup items (that were check before), and then check rest of the half items. Check the issue again.......
10. Now, if the issue occurs, then make a note of all the names of the startup items and then follow the same procedure, for them. Now, you need to be careful, as by design the System Configuration will sort all the enable startup items to the top. So, it means all the entries would be mixed on next reboot. From now on you need to make a note of all the entries that you're enabling or disabling........
I know guys it's a bit lengthy process, but trust me it works in both XP and Vista. I'm one of the Microsoft XP/Vista Techs............BEST OF LUCK...........!!!!!!!
Dec 29, 2009 | Microsoft Wireless Laser Mouse 5000
Compaq n600c hang problem plz slove my problem
Please give more information Like --
After how much time it hangs?
what OS u r using?
in general answer --
open task manager (pressing CTRL,ALT, DEL keys) this will bring up Windows Task Manger, click on Application, highlight any task that is Not Responding and click on End Task.
Also, to make your CPU boot up faster, I would
click on Start
click on Run
type msconfig.exe (this will open System Configuration Utility box)
click on the Start Up Tab
(you will see several boxes checked under Startup Item). And look for programs that you don't want to launch every single time you log on. (such as Realpayer, yahooMessegner, realsched, etc).
Uncheck the boxes and this will require a reboot. Your computer will bootup a lot faster. These programs you can always open when you want. You can always tell if you have a lot of programs that startup when you turn on your cpu and in the righthand corner, where the time time is at, you see a lot of icons.
Also if you can always open up task manager again, click on Processes, find explorer.exe and kill that process, this closes everything on your screen. dont worry...
then in task manager
click on FIle
New Task Run
and type explorer.exe and click OK
and you will see all your icons pop back up on the screen.
Post reply....
Thanks
Mar 22, 2009 | Compaq EVO N600C (Refurbished) 14.1" LCD...
My iternet was working and now it doesnt
Test connection, see if you pulled an IP address
Go to the Windows desktop
Select Start then Run
In the text box type: cmd (WIN98/SE type command)
At the command prompt type: ipconfig
4. What does it read as the IP address?
* If it reads 192.168. something dot something then you are pulling
an IP address and are connected to the network. The problem is
software related, check your firewall, and wireless card configuration.
Also check any WPA or WEP encryption keys. Check with the respective
manufactures.
* If it reads 0.0.0.0 for the IP address you are not connected to the network.
* Check your connection configuration and the adaptor.
* Check with the respective manufactures.
STEP TWO/ Basic troubleshooting continued....Testing the adaptor
1. Go to Windows desktop
2. Select Start then Run
3. In the text box type: cmd (WIN98/SE type command)
A DOS window will open.
4. At the prompt type: ping 127.0.0.1 (reserved IP address for all adaptors)
5. Check the line that reads "packets sent = 4, Received = 4, Lost = 0
A. Zero is good, the adaptor is working. Again check the connection
configuration,and the adaptor configuration.
It may be a power issue especially with older or less expensive computers
or wireless cards.
* Check the antenna location, are you inside or outside, look for interference.
B. If it reads all 4 packets lost, the adaptor is not functioning.
* Check and update the drivers, Contact the respective manufactures.
* If it shows any number of packets lost (you are dropping packets)
it is an adaptor or signal strength issue (generally form the laptop side,
not being able to reach back) especially with older or less expensive
computers or wireless cards.
* Update the drivers
* Check antenna location, or distance from the signal
* Contact the respective manufactures.
Nov 13, 2008 | NetGear DG834G Router
SONY VAIO VGN-NR21Z DOESN'T SEE WIFI
Be sure that your wifi button is ON
Be sure that your wireless network is working
Check your wireless router settings
Check if you see any other wireless network available on your computer
  1. Go to the Windows desktop
manufactures.
or wireless cards.
Nov 06, 2008 | Computers & Internet
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
The System Configuration Utility dialog box appears.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
HP OfficeJet t45 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
