Question about Samsung SyncMaster 740N 17" LCD Monitor
Color quality When I start my computer the computer is on normal color quality of 32 bits and then it goes to a 8 bit color quality and sometimes when i start programs it goes back to 8 bits until I end the program which then it turns back
  • 558 Answers
This is normal function of the programs some programs do not reset your resolution so you may have to do it manually. candy land did this repeatedly in my daughters computer.
Posted on May 11, 2008
How do i load a34bit onto a 64 bit system ?
Normally, a 32-bit program will run fine on a 64-bit system. However, a 64-bit program will not run on a 32-bit system. In a 64-bit system, there are sometimes two directories for program files, one for 32-bit programs and one for 64-bit programs.
If you are trying to load a 32-bit operating system over a 64-bit operating system, I think you loose everything on the 32-bit system, so make sure that you backup all your files. Another alternative would be to make a dual boot system, where when it boots up, you have the choice of going into the 32-bit system or the 64-bit system.
Good luck,
Paul
Mar 26, 2016 | Computers & Internet
I have problem with color setting
· open Control Panel and select Display menu and open it
· Then select Settings Tab from where you can change resolution and Color quality as 32 bit /64 bit
· ]Or you can click on Advance where you can set DPI
If you want to switch in 256 color
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don
May 22, 2011 | Computers & Internet
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
I haVE WINDOWS 7 HOME premium desk top and each day on certain web page using flash player 10 my internet explorer 8 shuts down saying a problem with web page caused internet explorer and windows to...
Is your system running 64-bit or 32-bit? To find this out, press "start", right click on "computer", then click "properties". There it will specify your "system type" (64-bit or 32-bit). There is no Flash Player for 64-bit Web Browswers available yet. If your computer is running 64-bit, you should try using the 32-bit Internet Explorer (can be found in your list of programs in the start menu).
Jan 08, 2011 | Microsoft Internet Explorer 8
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
Display suddenly becomes pixelated or fuzzy
just goto mycomputer then right click select properties
display setting adjust the bit of the color make it 32 bit
or if your O.S vista just right click on the desktop click personaliza display setting. change the color into 32bit .
Mar 05, 2010 | Dell Vostro 1310 Notebook
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
IE 32-bit browser need to run on my 64-bit browser
Hi buddy323,
You will find the 32 bit browser on your Vista installation disk. Or your restore CD from Dell.
If you can't find it there, you can download it HERE. Or may want to go for the IE version 8.
Good Luck and don't forget to leave a rating.
Thanks Mark
May 01, 2009 | Dell Inspiron 530s Desktop Computer...
COLOR QUALITY
click on start, then click control panel, find the icon that says display and click on it, when it opens find the tab that is for settings and click on it, there you will find your color setting options, click 32 bit,, then click apply and that should do it. you may have to reboot. good luck
May 15, 2008 | LG Studioworks 563N 15" CRT Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
