Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Check water i have a bosch classixx dishwasher and the light come on saying -check water.I have checked the pipes, all are clean.What could be the problem
  • Anonymous May 20, 2008
    I have the same machine and have exactly the same problem.
    The machine appears to be taking in water, gurgling and chucking the water out again. The 'check water' light comes on. I have checked the pipes as far as I can, removed parts from the inside to check for obstructions etc. When I reset the machine, it appears to start a new wash cycle, but then goes back to the 'check water' state.
  • jay63 Dec 14, 2008
    i have the same problem . how much can i expect to pay to solve this
Very possibly you have a faulty water flow switch. If a certain flowrate is not detected within a certain time, that light would come on
Posted on Mar 27, 2008
2 Suggested Answers
SOURCE: Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Posted on Apr 27, 2011
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher saying check water also not washing or spining
Bosch dishwashers have a food filter to catch food particles. You have to clean it occasionally, or it plugs up and stops water flow. This could be your problem. (Most other makers use a little grinding blade to finely chop the particles so they can be sent down the drain.)
Oct 04, 2010 | Bosch 24 in. SGS43C12 Classixx...
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch sgs53c12 dishwasher and the water light keeps comming on after about 20 seconds into a programme. I have switched it off and on, reset it and checked the inlet hose where it connects to the...
Hello- Bosch installed an anti-flood device in bottom of unit. If water gets into this area ( from a leak, usually). To get water out, tip backwards, then forward. Use a couple of towels- water should come out. Common problem with these units. Let me know if this info helps- have more if needed.- Thanks- Ed
Mar 12, 2010 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
2,299 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
