Question about Mitsubishi VS-50502 50" Rear Projection Television
Mitsubishi Projection TV Model # VS-50502
The TV has been doing some real wierd things lately. Initially the screen would start to flutter and then the screen would completely black out. If you powered down the unit and waited about 10 minutes before powering back on, then it would seem to be OK until next time (this usually happened once a week). Recently the TV did the same thing, but it powered itself off. Now, I can't get the TV to stay on more than 10-15 seconds. When I try to power it on, it makes this wierd pulsating noise from the back of the unit and then it powers itself off again. It doesn't power up long enough to even get a picture on. Any thoughts on what the problem may be? Could it possibly be a bad power supply? Please help with your expertise.
  • Needinghelp1 Mar 04, 2008
    The technician that I called in wasn't exactly an expert with rear projection televisions. He was unable to diagnose and fix the T.V. I offered him the comments that were suggested by sedonix and he didn't seem too interested in them (probably because of his inexperience). So, honestly I can't even make a complete conclusion on whether or not the suggestions would have worked.
    But, thanks for responding to my problem. It is much appreciated.
  • dhapp60 Oct 20, 2008
    Same situation use to have periodic picture going dark. now the TV does it after about one minute, but the power and sound stay on.
  • 579 Answers
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Feb 13, 2008
Does anybody have a download of a repair manual for a mitsubishi
User-Manuals.com has them in .pdf for $14.99 for download. Not a fix for a borrow but yours to keep.
Mar 25, 2009 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi vs50502
That's a convergence circuit failure. You may have to have the convergence output IC(s) replaced. Sometimes, if you catch it early and its still intermittently doing this, you may get lucky and only have to re-solder the pin connections under the convergence IC(s). If you're not up to doing this yourself, contact a Mitsubishi authorized service center. If the IC(s) need replacing, expect to pay $400-$500 to resolve this issue.
michtech
Feb 14, 2009 | Mitsubishi VS-50502 50" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Lines across my tv
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Nov 03, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
218 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
