Question about Philips HDD1630 MP3 Player
Philips hdd 1630
Change battery hdd1630
  • wedhj Feb 17, 2008
    brilliant.thank you wedhj.
Brilliant.thank you.
Posted on Feb 17, 2008
  • 476 Answers
The battery in the HDD1630 can be changed, but it's a bit fiddly to do.
Remove the hex screw from the back of the casing.
Gently lever the back cover off by insert a small flat blade or metal strip in between the front and back cover at the top. (Do not try to pull it off from the bottom.)
Tape along the buttons and switches down both sides of the player, so they don't fall out when you remove the front cover.
Undo the four cross head screws in the corners of the inner panel.
Gently ease the inner workings away from the front casing. Note the ribbon cable to the front panel.
Ease the buttons on both sides away from the inner casing. They are only stuck down with double sided tape.
Lift the metal plate away from the battery and hard disc, taking care not to pull the microphone out of the plastic end cap. (If it is pulled out, it can be stuck back in place on re-assembly.
Carefully lift the battery away from the board from the end opposite the wire. Pull the battery connector out of the socket and replace.
Re-assembly is the reverse procedure.
Posted on Feb 16, 2008
1630 mp3 player
There is none for this model. Press the on/off and volume + key at the same time. Sometimes I get so excited, I forget to do last-minute editing.
Mar 28, 2009 | Philips HDD1630 MP3 Player
My Philips HDD 1630 is having problems with synchronizing with windows media player 10, and i've downloaded the hardware for it also
Make sure the hold/lock is not engaged.
If not:
Here is something you can try:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 12, 2009 | Philips HDD1630 MP3 Player
Need assistance regarding my philips gogear 6gb HDD/1630/17 mp3 player
-Tha Mp3 Doctor
Nov 30, 2008 | Philips HDD1630 MP3 Player
MY PLAYER GOGEAR 1630/17 SCRENN FROZEN GOGEAR
try resetting the device by pressing the on/off button and the volume up button at the same time.
Sep 03, 2008 | Philips HDD1630 MP3 Player
Shows "this device cannot start" when i plug in the device
My advice to you would be to go get a new media player that isn't a phillips product. The headache that the hdd 1630 caused me almost made me go insane. I spent countless hours on the phone with tech support. They even sent me a new 1630 that I had for 2 months when the same problems happened again.
This thing is nothing but a expensive paper weight.
Mar 28, 2008 | Philips HDD1630 MP3 Player
MY Philips HDD1630 MP3 MEMORY APPEARS FULL WHEN THERE ARE NO FILES ON IT
Go to my computer open the Philips icon till you get to the music file delete it. Unplug the player from the usb cable and then reattach it. It will then show a new music file and 5.7 space available. All of your music will be gone.........but it was gone anyway. Ideally you should go to Philips and download the HDD1630/17b software and firmware and print off the instructions and redo your player. I did and it works great!!!!!
Oct 16, 2007 | Philips HDD1630 MP3 Player
Philips hdd 1630 mp3 player.
Down load the new Device manager and let it update you with the new plugins. Make sure your software is set to support pictures.
Oct 05, 2007 | Philips HDD1630 MP3 Player
Disconnect from computer, reset player, and try resyncing again.
-Tha Mp3 Doctor
BATTERY for 6gb mp3 player
i'm not sure what kind it uses but try Batteries plus. they have zillions of batteries. http://www.batteriesplus.com/
Sep 14, 2007 | Philips Sport Personal CD/MP3 Player
Philips HDD 1630 won't charge
I have the same problem I think that the internal battery died... is it possible to change it?
May 22, 2007 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player Logo
76 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
