Question about Toshiba 42H81 42" Rear Projection Television
Tv picture is shakey
Picture is shakey for like 5 minutes until TV is warmed up, then pic is perfect. Once TV is done shaking the problem doesnt happen again until TV is left off for awhile.
  • brinicol Jul 08, 2008
    I also have the same problem with a wavy shaky picture until the tv warms up for 5-10 minutes then it is crystal clear and steady. Do you know have costly it would be to fix, or if left will problem worsen. Thanks.
    Genius:
  • 1,694 Answers
Bad capacitors on Hyper module = no longer available, but
can be rebuilt by PTS Corp or a qualified tech...........T.
Posted on Feb 13, 2008
Partial picture frozen
Hi Robert
Possibly bad video memory.
LSI Chip failure until warms up.
Feb 24, 2014 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
HI, i Have a 42" lg3000 lcd tv when I switch the
Hello, I have exactly the same problem with the exact same TV, white screen for about 15 minutes and than image appears perfect as if nothing happened. I have asked an ebayer which sells TV parts and he suggested it could be a main board or tcon board. I am quiet hesitant to fix my tv, but if the tcon board would fix it, i'd go for it. Did You manage to solve the problem yet?
Mar 29, 2011 | LG Televison & Video
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Tried turning on my Sony and no picture no sound, just a black screen
Sony is known for having problems with the picture tube. Sometimes it will blink on and off. also bad connections on the main board. A CRT restorer will sometimes help with picture tube problems but this must be done by a tech that has one.
Apr 11, 2008 | Televison & Video
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Video distortion
unplug the tv before you go to work or for a couple of hours then plug it back in and let the tv warm up for 15 minutes and adjust the covergence
Dec 11, 2007 | Televison & Video
Shakey Picture
bad cap, spray some freeze on it till it comes back and you will find the bad part.
Nov 17, 2007 | Toshiba 65HX81 65" Rear Projection...
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
198 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
