Question about AudioBahn A4KDN Car Audio Amplifier
UPGRADES FOR A4KDN AMP
I'am to the understanding that A4KDN AMP is the same circuit board as soundsteam xxx6500,this amp has a rating of 6500watts @ 16volts.Can the A4KDN produce this power output as well?
16v is a new upgraded alternator, upgraded possibly even 2 batteries and more than likely having atleast an 8v signal coming from the rcas. this would be possible with the 4k they approximated its max to be 8k watts even though thats unrealistic its "possible" im sure you could upgrade this stuff and get it close only thing you have to remember is they amps rms. you should only run it at its rms wattage output if you dont your asking for the amp to break and be sent to a person.... well like me who repairs broken amps. and trust me i dont work for cheap.
Posted on Sep 19, 2013
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
Tip
2003 montero(battery cable accidentally crossed)
This would be a case history. Probably too difficult for a mechanic to have troubleshoot.
Symptom- A fusible link kept blowing out. (It looked like a big fuse rated at 200 amp if I remember right.
Cause - At the back of the vehicle by the passenger side, there is a factory amp that powers the vehicles sound system that had caused the short.
Solution - Unplug the factory amp, causing the short. Open it up and replace the large diode with a good one. (I used one I pulled out of a junk circuit board.)
Note* The vehicle was taken to several different shop but could not find the problem. This was definitely a job for an auto mechanic who understand electronics. I saved the customer lots of money because he did not have to buy a factory amp, and pay a dealership 90 bucks an hour while troubleshooting the vehicle. which would have easily ran him a thousand bucks or more. Since the problem was evaluated accurately, there were no wasted money buying unnecessary parts.
on Feb 18, 2010 | Mitsubishi Montero Cars & Trucks
I had a house inspection and in the main panel I have a 20 amp QT breaker that is rated from 15-35. I have a 20 gauge wire and and a 15 gauge wire running to this breaker. Inspector says I need a 15
He is correct. I'll not go into the particulars but the fact is, you have two separate circuits connected to the same breaker. Separate the two circuits by installing another 15-Amp breaker. Although I understand your situation, please understand wire gauge and electrical amperage are two different animals. Breakers are rated in Amperage and electrical conductors are sized by wire gauge. That said, the 20 gauge wire you speak of is actually a 12 gauge conductor and the 15 gauge wire as you say is a 14 gauge conductor. Have a good day.
Aug 30, 2014 | Siemens Ite Twin Q1515 Circuit Breaker...
Need information on circuit breaker BR2100 60amp
Hi - I'm an electrician and can help you with your question.
A BR2100 circuit breaker is a 2 Pole 100 Amp (for the part number "BR2100", the "2" indicates the number of poles and the "100" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
A BR260 A BR2100 circuit breaker is a 2 Pole 60 Amp (the part number BR260, the "2" indicates the number of poles and the "60" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
It is not possible to have a BR2100 rated for 60 amps, 1 or 3 poles, or a BR260 rated for 100 amps, 1 or 3 poles.
It is not permissible to install any circuit breaker brand or type in any panel that does not specifically include it on a list of acceptable circuit breakers.
Circuit breakers are designed to carry 80% of the amperage rating.
To determine the load a circuit breaker can carry, multiply the circuit breaker amp rating by 80%.
This means that if you need to supply more than 80 amps, you cannot use a 100 amp circuit breaker. A higher rating is required. A BR2110 would be acceptable for loads greater than 80 amps, but less than 88 amps because the formula above says: 110 amp x 80% = 88 amps.
To determine the breaker size, determine the load (by measuring with a meter or obtaining amp rating of the load from the data plate) and multiply it by 125%. Using the same numbers in the example above; assume an 88 amp load. 88 amps x 125% = 110 amp circuit breaker. The 60 amp breaker is acceptable for up to 48 amps because 60amps x 80% = 48 amps. A 48 amp load needs a 60 amp breaker because 48 amps x 125% = 60 amps.
I hope this helps and good luck!
Jan 15, 2013 | Eaton Corporation BR2100 Circuit Breaker
Soundsteam 1.800 amp rubicon protection light stays on green light chirps. How do I reset the amp?
disconnect the speaker wires from the amp, and check for power. there is no resetting, other than simply turning the amp off and back on. if it powers up fine without the speaker/sub(s) connected, check your wiring and check the ohms with a meter. if you do not find a problem there(should read within 1ohm of how you wired it) then check for dc voltage coming out of the speaker terminals on the amp. should also check that the amp is getting good power and ground. if wiring and speaker(s) check out okay, then the amp is damaged. if you get dc voltage from the speaker terminals, the output transistors are shorted out and it needs to be repaired by a tech.
Mar 08, 2012 | Car Audio & Video
My circuit board on my tevion surrond sound has blown a fuse can i get a replacement for it
Yes you can and when you replace the fuse and it blows again then you have a fault that is causing to blow.
The fuse has an amp rating and this is marked on the end cap, replace the fuse with the same amp rating.
Apr 26, 2011 | Computers & Internet
Need mother board drivers
Drivers for D845GVSR:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVSR
CreativeTECH
Nov 11, 2010 | Intel D845GVSR Motherboard
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
What size amp switch do I need.
NO! Use a switch rated higher in amps and equal to or higher in voltage relative to the breaker rating. Use a 40 or 60 amp switch rated a minimum 220 volts.
Feb 26, 2009 | Connecticut Electric 40 Amp 2 Pole Circuit...
Whats is the perfect amp?
I have 2 of these 12" running in a Large slot ported box with an:
"Ultra Linear UL2402"
600RMS X 2 @ 4Ohm (Stereo) 1200RMS X 2 @ 2Ohm (Stereo) 2400RMS X 1 @ 2Ohm (Mono)
Can be run in Tri-mode with 3 8Ohm subs, which these subs are. I have not tried this mode. This is
600RMS X 2 @ 4Ohm = Max RMS of your subs. You should run the max of your subs, less wear on the amp you are using , and i doubt you will ever need to turn it up far before it blows out your trunk or window :P
1200RMS X 2 @ 2Ohm = Blown Subs!
Has 4 x 25amp fuses, most will tell you this only has an RMS of around 845, an "ultra linear circuit" produces twice the output power over Modern amps.
Can had on Ebay for around $100. I bought mine for $101.
This Amp pounds, i could quickly tell a difference going from 300RMS X 2 @ 4Ohm with a Kenwood amp. I Had to turn all my settings down on the new amp to have a better balance in sound.
Jan 29, 2008 | Volfenhag ZX-4712 Car Subwoofer
Car Audio & Video Logo
74 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Iron
Iron
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
