Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon Pixma MP530 clicking
I'm getting a very loud Clicking noise every time i turn the printer on, after every print and also when the printer is turned off. I've had no paper jams, the cartridges are orignal and i've not forced the carrage at any time. there's nothing stuck in the printer. the print quality is still very good and all the other fuctions work fine. if any one can offer any information it would be a great help
  • 8 more comments
  • squalleye Feb 14, 2008
    Same thing - the printer is possessed - it makes random loud repetitive clicking - everything else works fine
  • artifacts Feb 17, 2008
    Just installed and indeed it clicks. What's up?
  • Josh1953 Feb 20, 2008
    Same problem with me and I have the printer now a year
  • CWMaidsone Feb 21, 2008
    The Clicking i get is not electrical, it's more of a stuck cog clicking but i don't know which cog it could be because everything works fine.
  • ilbmiller Feb 24, 2008
    VERY loud clicking noise when 'warming' up before printing (wakes kids up in the next room...), but everything works fine.
  • Anonymous Mar 24, 2008
    Loud noise, clicking after printing, every time. Have taken no steps to resolve problem.
    Thanks
  • hpliao77 Oct 23, 2008
    I have the same issue. There's this loud clicking noise every time it's turned on or when there is a fax coming in, or a new print job.
    Checked the phone jack it's fine.
  • tomcf Oct 24, 2008
    When turning on the printer and while preparing to print, there is a loud sound like plastic gears stripping. I don't know if there are timing gears or if there's a track that it might have slipped from that is causing it. The printing is fine, but am sure something's going to either burn out or strip smooth.
  • drgwentzel Jan 12, 2009
    I have the same issue of clicking on start up. It is like a gear is being grinded. Has anyone called Canon? GW
  • Anonymous Jan 26, 2009
    I have the same problem & it cant be anything to do with phone jack as Ive never had it hooked up to phone and it used to work great.
It is nothing to do with a phone jack, trust me this sounds like internal crunching and munching... but as reported by the others, no jams, no printing errors, just loud clicking and clunking!
Posted on Mar 11, 2008
  • nospam181 Dec 09, 2010
    Same loud click/grinding here too. I will *NEVER* buy a Canon printer again in my life.
Yep the phone jack; it was in the wrong one.. The clicking stoped. Thank You!!
Posted on May 28, 2008
I had clicking when I set up the unit. I realized I plugged the phone line into the wrong jack. The clicking went away when I found the right jack for the phone line.
Posted on Feb 21, 2008
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
Oct 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
My Brother ALl-in-one makes a loud clicking noise
Your printer almost death, just buy a new printer would be the best way.
Feb 20, 2009 | Brother MFC 7420 All-In-One Laser Printer
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Loud clicking noise
This is one of the known issues with the HL-5240. This will require a replacement paper tray. Definately the problem if it is more of a clack than a click.
Sep 18, 2007 | Brother HL-5240 Laser Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,345 people viewed this question
old marine
old marine
