Question about Sony VPL CS5 Multimedia Projector
Problem: Green colour cast
Pronounced green colour cast when connected or not connected to VGA computer.
Setting Input -A Signal Sel = Computer
I have checked connections, video cable, Hue, Colour etc. with no success.
  • SatanSlut Feb 15, 2008
    i have same problem but the words are blurry but the focus works fine .. is the mirrors dirty or color correction on the board bad on my Sanyo plc-su30 lcd projector
Problem resolved by swapping the video cable, simple really!
Posted on Feb 14, 2008
My smasung monitor sync master 753 vga connector broken, what is color scheme for new connector
Colour scheme to re wire is as follows...
Pin Name Function 1
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Hope this helps!!
Jul 19, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Tip
How to Install Speakers on your Computer/Laptop!!!
At the rear of your computer you will find the I/O, this is known as the In/Out of your computer mainboard.<br /> <br /> Here you will find various input and output ports, these include USB, VGA out, DVI, HDMI, Firewire, e-sata, audio in/out, PS2 for mouse/keyboard, etc...<br /> <br /> In this case we want to connect speakers to our computer, so we want to find the audio out 3.5mm jack. It is colour coded GREEN. Insert the speaker connector into the GREEN 3.5mm jack.<br /> If you have a sound card installed you will need to plug the speaker connector into it's GREEN 3.5mm jack.<br /> <br /> Below: The I/O of your Computer Mainboard, the red elipsis indicates the audio in/out. We are going to be using the GREEN one shown!<br /> <img src="damnor01_13.JPG" /> <br /> If at this point you don't get any sound from the speakers you will need to install the audio drivers for your specific computer mainboard/sound card.<br /> Use the CD provided with your Mainboard/Sound Card alternatively use Google!<br /> <br /> Happy Listening!<br /> damnor01
on Jan 03, 2011 | Computers & Internet
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
No Input Signal
Dont Panic it is Nothing...
Your Monitor is safe...
If it say "no Input signal" - "Check VGA cable"
it means that the Monitor is finding signals from the computer,and the cable is either not connected or unsecurely connected.
Jul 18, 2008 | Chi Mei Corporation 221A Monitor
Connecting Projector to High Def Source (e.g. PS3 HDMI)
That projector supports M1-D also which is the digital side of the M1-DA... Anyway, they sell cables that are M1-D to HDMI to which you can hook directly to the PS3. They are decently priced too, less than $20. I know this thread is old, but I came across it due to an issue I am having with my xb31, broken color wheel. Trying to find parts...
Feb 06, 2008 | HP Digital Projector xb31 Multimedia...
Sony VPL CS5 Multimedia Projector Logo
222 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
