Connecting panasonic Viera to sky, video and dvd home cinema system
We have just bought a panasonic Viera TV and panasonic dvd surround sound system. We have Sky and an LG video. We also have tvs around the house that were able to pick up sky (not multiroom) and terrestrial channels with reasonably good pictures. Now we have no SKY on the other tvs and no decent picture. We have got a booster 3 + 3 DGb(?) which is in the video aerial slot.
We got a roadmap from a techie that put everything through the video which worked for all terrestrial channels but sky didn't work and we could only use the video remote and not play around with the TV remote
Techie's I need you help!!!!
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
  • 138 Answers
SOURCE: Sky remote code for JVC GM-P420E
Go to www.remotecentral.com
Posted on Aug 19, 2008
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Posted on Jan 07, 2009
SOURCE: sky remote code
try 0210
Posted on Feb 06, 2009
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I cannot get surround sound to work when watching normal tv or sky,i have a samung tv and samsung home cinema system.how can i correct this
cant get surround sound through tv but works on dvd???
do ineed a component cable from dvd to tv?
tv= samsung le40c530
dvd= samsung ah68-0041oy
Feb 05, 2010 | Samsung HT-Q100 System
Have today bought Ferguson FHT1000 5.1 Channel DVD home cinema system can i get surround sound to work on tv or will it only work on dvd
it will work with your tv providing your tv has the correct output and you have the right cables. the programme must also be broadcast in surround, most programmes are only stereo. if you are running sky or sky hd this will be different so repost.
Dec 20, 2009 | Audio Players & Recorders
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Surround sound
You need a cable from your audio outlet to the home theatre receiver. Veira link is just for the picture. Only one way transmission. Optical cable or the 2 wires. Both options are available.
Nov 17, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
380 people viewed this question
Top Televison & Video Experts
