Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Parallel connector Hello, Can you tell me if the Panafax UF-490 has a DB36 or DB25 parallel connector?
  • 31 Answers
You can only use Printer cable for u to be able to connect the unit to the PC
Posted on Mar 11, 2008
How to connect to the computer?
Devices: Canon CanoScan FB330P/FB630P Color Flatbed Scanners
Check pages 22-23 of this copy of your Canon Canoscan 630P Product Guide.
You'll need an "IBM-type" parallel printer cable - with a DB25 on each end, and your computer will also need to have an "IBM-type" DB-25 parallel printer port.
What the Canon Product Guide fails to mention is that this "IBM-type" printer cable is a kluged Centronics parallel printer cable, but became so popular (on older computers - your laptop may not have this port), that it got an IEEE standard: IEEE 1284 (with DB25 connectors on both ends).
You'll need a DB25-to-DB25 M/F cable, meaning DB25 connectors on both ends, with a Male on one end, and a Female on the other end.
The Male DB25 will plug into the Female DB25 connector on your computer/laptop, with the Female DB25 going to the FB630P Color scanner..
Here are some pictures/pricing:
http://www.computercablestore.com/IEEE_1284_Printer_DB25_to_DB25_catID2134.aspx
The nice thing about the design of the Canon FB630P Color Scanner is that the scanner also has a Female DB25 Printer port for an existing parallel printer, so when you connect an FB330P/FB630P to your system, your existing parallel printer is daisy-chained through this port - so you needn't give up you printer (to scan), nor must you install another parallel printer port onto your PCI-bus tower PC to keep your printer.
Canon Canoscan FB330P/FB630P Color Scanner Product Guide (82 pages):
http://canoncanada.custhelp.com/ci/fattach/get/267/
Most modern printers are USB-attached to laptop systems, so you may need an adapter, an example of which is seen here:
http://www.cablestogo.com/product.asp?cat_id=116&sku=16899
Dec 05, 2011 | Canon CanoScan FB630P Flatbed Scanner
I lost the printer cable (to PC) of Panafax UF-490. How can I buy it? Thank you
What you need is a PARALLEL printer cable.
They come in various lenghts, 6 feet being the most common.
Every computer store has them. Their price is around $10.00
No decorator colors, sorry.
Jun 01, 2011 | Panasonic Panafax UF-490 Plain Paper Laser...
Panafax UF-490 fax problem
your lsu unit must be dirty or check your drum unit
Feb 25, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
DOES panasonic PANAFAX uf-490 compatible with window vista 32 bits
uf 490 is not compatible with vista but the upgrade version uf 4000 is.. try the driver might work <http://panasonic.net/pcc/support/bfax/uf-6000/index.html>
Sep 27, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Cant send faxes-a panafax uf-490
PLEASE I NEED A CD ROM OR DRIVER FOR PANAFAX UF-490 SO THAT I CAN DOWNLOAD UNTO MY COMPUTER AND THE FAX TOO IS NOT WORKING THAT MUCH,HOPE U CAN GIVE OR HELP ME,THANKS
Feb 26, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
I'm not sure if I have the correct cord or if I have it pluged into the correct port.
It is either a usb "A" connector which is the squarish side of the usb cable and the flatter "B" connector is the side that goes into your computer's usb jack. Some printers, like yours also still use a parallel port which is a Centronics big, wide rectangular connector that connects to the printer side and the other end is a DB25 parallel connector than goes to the parallel DB25 printer jack on your computer. You must have at least one of those cables but you only use one or the other. The usb will be configured to a usb local printer port or the parallel will use the LPT1 port. HP.com will provide you with a quick install brochure with pictures for you to see. post back if you need more help! Steve Medley
Oct 21, 2008 | Office Equipment & Supplies
PANAFAX UF-490 and VISTA
for alsader1
you can try a uf4000 print driver its just the newer version of the uf490
http://panasonic.co.jp/pcc/products/en/bfax/download/uf-6000/gdi/eng.html
for salva0804
you can not get copies of what you faxed out. you could print a com journal for future faxes
function-7-4-start-1-2-start-2-start-stop
Apr 19, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
64 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
