Question about GE 29490GE2 Corded Phone
GE phone 29490GE1
I have a couple of these which have suffered a lightning surge and its getting a bit expensive to keep buying new ones. They still function but not fully. I need a circuit diagram. Can you help?
Would be nice to send it to you for repair but I live in South Africa which makes it a bit difficult.
PS
The local GE agent is not interested.
Thanks
  • 96 Answers
SOURCE: My RV unit got a power surge and the microwave looks dead.
Yes they have fuses, I am positive it's your fuse, take all 5 screw's off and you'll see it at the back on the right hand side were the ac cord goes in.
Regards
Bob
Posted on Jan 20, 2008
  • 537 Answers
SOURCE: where can i get circuit diagram of GE 7-4809
I doubt you'll be able to find a service manual for this. I would take it (if it means a lot to you) to a good repair center. They should be able to troubleshoot the problem even without a schematic.
Posted on May 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave
I repair GE circuit boards, but the problem is not your circuit board.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 19, 2008
SOURCE: broken coffee carafe
Was expressing my opinion. I will buy a different model when I find one Thanks
Posted on Jul 31, 2009
  • 172 Answers
SOURCE: answering machine leaves the telephone line open
Chances are it did not damage the control(operating) curcuits, but most likely the Telephone curcuits in the answering machine.
Posted on Aug 11, 2009
Hi My Sansui 42 " flat screen got steuck by lightning it turns on and I can play a couple and did. Problem is that the screen is not full it's half
Purchase a new one, anything could have happened after suffering a strike and voltage surges. If you repair the screen, you may find something else fails shortly afterwards. If this is genuine, consult your household insurers.
Feb 17, 2017 | Sansui Televison & Video
Tip
Surges -- How to keep them from damaging your electronic devices.
Surges give me more than half of my repair jobs,so [1] it is best to simply unplug ALL of your best devices when you expect to be away for awhile, and [2] your purchase of a surge limiter will cost you less than $30 on the net, or less than $40 at Walmart or Lowes, or Home Depot, and be sure to buy a 6' length of coaxial cable at the same time unless you have one hanging around. [They are right now probably in a closet among a whole bunch of stuff that's just barely too valuable to throw away -- stuff that your sweetie has threatened to chuck any minute now.]
Your surge limiter must be rated at 3000 joules or more, and must have at least two shiny threaded 3/8th inch projections on it to accommodate coaxial cables. The limiters are easy to hook up, but you can email to me for freebie coaching if you need to. I am at GrampsCanHelp@gmail.com
Lightning will jump limiters sometimes, and they get tired after 3 or 4 years so must be replaced, but thereafter they remain valuable as power strips. They are far far from being perfectly protective because fragments of lightning strikes jump them and damage them, but they are the best devices that low cost technology has been able to bring to us to date.
[A 'back-up' power supply containing a battery and isolation transformer will be more protective but costs 3 to 6 times as much. You may wish to get more details about them from me, but they should only be considered for VERY expensive or very precious devices.]
Hope this helps.
Gramps
on Feb 02, 2015 | Bits Limited Smart Power Strip Scg5 W/...
My window unit got hit by lightning and blew the plug right out of the wall, although it had a surge protector on it- it does not work now- any ideas on what I could try to fix it like a new fuse or...
As you saw a surge protector doesn't stand a chance against lightning!!!
The unit is toast... turn it into homeowners and buy a new one...
heatman101
Jul 12, 2011 | GE Heating & Cooling
My FF 2125ATF answerer/phone is not working correctly. The handset clicks constantly and the buttons most of the time don't beep when pressed and then there is no dial tone. The battery pack has the...
It sounds as though your phone has been hit by a power surge or lightning. Try the phone at another location and try another phone at this location to make sure there are no problems with the line. I would almost bet you will find that another phone will work but this phone will not work at another location. Phones are very susceptible to a power surge and to a lightning strike. If another phone works at this location then just buy another phone. It will be cheaper than having this one repaired. Phones are cheap but repairs are not. Merry Christmas to you and your family.
Dec 16, 2009 | Southwestern Bell FF-2125BL Cordless Phone
Lightning's effect on my phone
hi there it looks like your phones getting fried by the lightning, perhaps the phone cables on the way to your house are getting hit, im not sure if theres such thing as a phoneline surge protector (try a good electrical store) or simply unplug the phone when god gets angry, good luck
Aug 24, 2009 | Nortel Meridian M26 Corded Phone
Surge at low rpm
Is it brand new? If so it's pretty normal. The bikes don't like running smoothly below 2k at all. As it breaks in it will get a bit better but it's difficult to not jerk it around at low RPM and slow speeds. Best bet is to keep the RPM at 2200+. Also if it is new when you get to the 1k TPS reset it should help as well.,,,
Nov 10, 2008 | 2007 Buell Lightning Long XB12Ss
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
No dial tone
Try the telephone cord from your cordless to another known working phone. I have had these cords go defective.
If the phone is really defective, it is possible that the input circuits that connect to the tele line are damaged. Common causes are voltage surges in the line or surges from lightning. Normaly these phone has protection, but this is not always absolute or fully dependable.
There are many other things that can fail in a phone to cause no sound.
If the phone is defective and it is under warranty, it would pay to have it fixed. If it is not under warranty, it would probably pay to buy a new one.
Jerry G.
Apr 13, 2008 | Panasonic KX-TG5632 Phone
Lightning Strike
Replace with new will need new main board (170 bucks) and modeum board, for best protection it needs a fax filter that protects power line and phone line, standard surge protecter only protects power line
Nov 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
GE 29490GE2 Corded Phone Logo
101 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
