Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
WD440 hotpoint washer dryer Leeks on spin from Tray
Machine will go through normal wash cycle but when it comes to rinse and spin the machine will leek water from the the detergent drawer, and there is a lot of it i have check that all of the screws are tight, unsure where to go next could there be a blockage in the system i have checked the waste hose and the machine will pump the water out ok with no leek.
  • 1 more comment
  • tri_stand Feb 26, 2008
    Have the same problem with my machine. After checking the pipe was clear (black one below the soap tray) and trying all sorts. I rang Hotpoint describing the problem, they said do a boil wash as this would clear any soap powders throughout the machine. Tried this, but 30 mins from end of program the machine won't spin even when the light comes on. So I used the pump-out feature and then done the Slow spin, Followed by the fast spin. No leaks. Then tried the rinse and spin feature, 3.5mins later water sprayed from the bottom of the tray to 2 feet away from the machine. Failing any possible advice from several forums, I will have to pry the wallet open and let Hotpoint rip me off with their costly charges.
  • rabidray Feb 28, 2008
    HELP - we have exactly the same problem!!!!
  • darth chris Feb 28, 2009
    i have this problem and will try this solution. cant do it now as the isolation tap[ has broken and i cant disconnect the machine! LOL!
After my wd440 leaked all over the kitchen, i followed the solution detailed above (posted on feb 29th) and it worked perfectly!
managed to find 4 colour catchers in the ball filter, so they have now been banned from being used in the machine.
also found £4.05 - so not all bad!
Posted on Jun 26, 2008
I have no solution for your problem but thought you might like to know that my new towels and my old towels and my sainted mother's knickers are tearing themselves to pieces. My Hotpoint mechanic told me so.
Posted on Mar 20, 2008
The solution from the Guest on feb 29th is spot on. I happened to have the Hotpoint engineer out this morning and he done the same thing. Works spot on now
Posted on Feb 29, 2008
I had this problem with my machine, but if you turn it on it's side and look underneath you can see a large rubber pipe, if you unclip this you will find a little cage and a plastic ball about the size of a golf ball. clean these and put it back together and it will work once again.
    Master:
  • 619 Answers
Hi , the electromagnetic water valve was leaking need to check or clean the devil contact gasket or either the vevil was rusted , the gasket cannot stop due to the surface of vevil was deteriorated.
check also the electromagnetic winding may open.
Posted on Feb 13, 2008
Hotpoint wd440 just fills and drains does not move on from wash cycle
it ran for two hours but where did the water go? if it was not cutting off water then u most likely need to replace the water inlet value
Apr 07, 2014 | Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
509 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
