Question about Panasonic DMR-E55 DVD Recorder
DMR-55E dvd recorder timer fault
It some times takes a long time to do a self check IE:- up to a Hr.
Secondly if you program a timed recording it gets 10 mins into recording stops for about 2mins then carries on recording.
  • 1 more comment
  • post610 Nov 13, 2008
    Had the same issue and solution worked for me so thanks very much. I am a novice but worked it out in the end. A picture would have helped in identifying the screws/board layout and I found I also had to remove the HDD t get access...but all good in the end....thanks.
  • velaveetil Nov 26, 2008
    System is not get switched on . Sometimes I can see the 0:00 flashes. But when press power on swich, nothing is happening.
  • vanbeet May 11, 2010
    Is there just 4 screws holding the hard drive in place on the E95, and could you tell me online supplier for regulator STRG 6353 can't seem to find them.
  • 185 Answers
This is a common problem with this particular model. I can tell you what the fault is but unless you feel confident in using a soldering iron, the repair is best left to someone who is.
Ok...the fault you describe is caused by failure of IC001. This is a voltage regulator on the power board. You can identify the regulator as it is fixed to along thin metal strip near the middle of the board. It gets very hot during normal operation and will fail after a couple of years. The metal strip offers very little heat dissipation so the regulator operate in excess of its limits and therefore fails.
You need to take the lid off, remove the board which is mounted on the right hand side of the unit and replace the faulty regulator.
To remove the board, remove the fixing screw above the power connector on the back of the recorder, then the 4 fixing screws that secure the board. Next carefully remove the multi-connector that connects the board to other circuitry and lift the board clear.
A new regulator type STRG 6353 and can be obtained from several online suppliers. The old regulator can be removed by unscrewing the fixing screw, cuttiing the 5 pins with wire cutters. Then using a soldering iron, carefully removing the residual pins from the printed board making sure the print is not damaged.
Use some heatsink compound on the back of the new component, this will help it to dissipate heat more easily, use an additional heatsink if you can, which will help to prolong the life of the new regulator, then tightly secure it in position before carefully soldering the 5 pins.
Check that you have soldered it correctly without any shorted pins or tracks and reassemble the unit. I have repaired dozens of these successfully with exactly this fault.
Mains voltages can be lethal so always remove the power plug before doing any work like this and be sure of your own ability. If you're not confident in tackiling this, get someone to do it. Whatever you do, don't ditch the unit for such an easy to fix fault!
From your user name, I guess you're a radio amateur, so you should be on home territory.........
Posted on Feb 14, 2008
  • Palmbeach
    Palmbeach Feb 14, 2008
    By the way, I would avoid using the recorder until you have repaired it. If the regulator shorts out, it will take several other components with it. I repaired one where a couple of diodes fried and part of the print fused and burnt, together with an internal fuse which blew.
Hi, Just to confirm the problem of constant sefl check on my DMR-E95H DVD Recorder is the voltage regulator STR-G6353 on the power board, you have to remove the hard drive to get to the board on this unit, but its not a difficult job, bought part from NIKKO electronics, cost £6.33, get some heat sink compound as well to put between the heat sink and the new regulator, total time to do the job, approx 45 mins, recorder now works perfect and the advice on FIXYA saved me a lot of money, Thanx.
Posted on Oct 06, 2009
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Self checking
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 04, 2009 | Panasonic DMR-E55 DVD Recorder
Recorder keeps 'self checking' then taking dvd back to begining, although only on recordable dvd's, not rented. Are recorders worth repairing or are you better just buying another?
Dec 02, 2009 | Panasonic DMR-E55 DVD Recorder
Player shutdown and then go to self check
unit goes in to self checking over and over dvd can not be ejected and will not function at all?
Aug 05, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E65 cycling in self test on start up
Check the IC in the primairy power supply,common fault.
Jul 22, 2009 | Panasonic DMR-E65 DVD Recorder
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
4,395 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
