Question about Car Audio & Video
No power to my legacy 600 watt car amp
Hi im having problems with my amp it worked fine in my old car but now ive put it in my new car theres no power going to the amp ive checked it with a volt meter ive got 12.43 volts going to the amp but it still wont work its just gone 12months old and the the warranty has just ran out typical any help will greatfully be received
  • 1 more comment
  • bmerr18 Feb 20, 2008
    k I'vw got a problem I've got a sony xplod xm- 1652z 1000 watt amp w/ 2 10 inch sony xplod subs. k so here's the problem I've got power to the amp like the power protection light is green but then I cant get my subs to work (btw I'm only running sub till i get the another amp) kinda like there's no signal also when I put the rem wire into the plug port in the back of my xplod deck it beeps a couple of times and then I cant adjust the volume and I still have no sub signal any help?
  • beinghuman Mar 06, 2008
    I have a similar problem. I have run all my wires from the same spots as I did previously (and they worked) but now I get no power to the amp. I don't get a green light or a red light or anything, just no power to the amp. I have checked all my fuses, installed new wires and anything else I could think of but still no luck. Any suggestions out there?
  • beinghuman May 11, 2010
    Thanx moneyman, I tried hooking my rem to the battery direct and next thing know I have sound..... is there any chance that this would contribute to engine whine though? I seem to have a minor whine happening now.
Aint got no power gowing to amp changed amps still no power connect my power cap up to the power lead and earth and there is power gowing to that why so there is power gowing through the
leeds just none gowing to the amp why is that eny one can help me?????
Posted on Jul 05, 2010
Hmm...ive had this problem before and its always been either the remote wire, the rca cables or the ground. i would try hooking up the remote wire strait to the battery, if that doesnt work try to find a better place for the ground. maybe where your trunk latches. if that still doesnt work then i would try new rca cables.
Posted on Feb 14, 2008
What ar the specs for a legacy LA420 600 w amp
This Legacy LA 420 amplifier features 400 watts of power, two channels (bridgeable), a two-way crossover, Mosfet power, 2 ohms stable, and THD less than 0.04%. The amplifier measures 10" x 9.5" x 2.75".
Oct 12, 2016 | Legacy Car Audio & Video
Hi i have a Samsung np-r40 and it dosnt charge or get any lights working, it works fine with a full battery so comp is fine but cant get it to charge or come on useing the mains ive brought a newcharger...
Something, a component, in the laptop may have fried the charger. I don't know for sure. You would have to trace the circuit with a multimeter to locate the bad power component.
Jan 12, 2013 | Computers & Internet
I have an ads power plate amp, im not sure what size, but it has 6 channels. it currently powers a 300 watt lightning audio 12"( so cheap= junk) an unknown brand or watt 10", and im trying to make it also...
Hello, what do you mean you have no clue to what's wrong? What is your problem your having with the amp? You did'nt say what's going on. Let me know the problem so I can better assist you.
Aug 20, 2009 | A D S Car Audio & Video
Legacy 1800 watt amplifier
Feb 06, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
My 600 watt amp for my car just now start putting a red light on
You may need a new power supply inside amp. If you where running speakers with to many watts it will burn up the power supply. Try unplugging all wires. Replug them in also check fuse underhood and inside amp
Dec 12, 2008 | Pioneer GM-7200M Car Audio Amplifier
600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Sep 08, 2008 | Legacy Audio American Legacy II LA490 Car...
No light at all
A couple of things you can try:
1. check for B+12 on the 1st and 2nd terminals of the Power Connector using a voltmeter;
2. temporarily put a jumper on the 1st & 2nd terminal of the Power Connector;
3. the usual, check for loose connection, fuses, wires, connectors.
if there is +12 on both terminal and amp is still dead, then it is internal;
if there is +12 on terminal 2 but none on 1, then it is the wiring from the head unit or the trigger of the head unit that is the issue;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 14, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Power Problem, LED Lights up and then shuts off
Do you have the switch or activate wire on the new amp. to the right hookup? If you do, then theres a problem with the amp and if your not a tech these can be a difficult thing to trouble shoot. Take back the amp or seek out a pro to test it on a bench. Good Luck
Jul 24, 2006 | American Pro VS1405 Car Audio Amplifier
Car Audio & Video Logo
413 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
