Question about Alcatel Newbridge MainStreet 3600 Multiplexer
DCC port problem-1
We use Alcatel Mainstreet 3600 Bandwidth Manager.
We have DCC cards(V.24 RS232) installed for RTU data polling.
For new RTUs we had to enable new DCC port.
When we make cross connection between DCC port & E1(64kbps channel)
the corresponding LED of DCC does not glow and the ckt is not established.
For example we did the following:-
ckt Name Type ckt Name Type
A4-04 RTU-5 RS-232 A2-13 PowerStation E1 NoSig
(DCC Protected by A1-13 Do E1 NoSig
card No. 4 (E1 card
Port No. 4) channel no. 13)
However the LCT software shows the cross-connect is done
Any assistance will be appreciated
Email: mizanhassan@yahoo.com
    Problem Solver:
  • 13 Answers
You have to forced ON the DCC lead on Config - Circuit - Options - CtrlLeads.
ilker
Posted on Aug 10, 2010
Mainstreet documentation
Hello Anton, I can send you the manuals, send me your mail address..mine is lenconradie@yahoo.com.
Regards
Len
Nov 17, 2011 | Alcatel Newbridge MainStreet 3600...
After a reset 90-0667-01 Controller Database to default setting can not have access to administrate
If you reset the control card to a "0" the SP ports will default to 9600 VT100. Make sure that you connect on the back plain SP1. Reset with"0" will only reset the SP ports. Reset with "1" will default your database and all connections will be lost. Access will be Level-5, Password-mainstreet.
May 03, 2011 | Alcatel Newbridge MainStreet 3600...
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
What is the function of expended card.how many band width of mux 3600 single shelf,doul shelf.27LC card suport daat limit.why we use expanded card in mux 3600?and DINC card use for how many data sopor
You mean Expander Card.
The original chassis was fitted with only 6 slots and thus the control card can only manage these 6 slot single bandwidth. (2Meg per slot). As the 8 slot chassis was develop it was I think cheaper to build a new card as to build a new control card to manage the other two slot (7 and 8). So the expander card was build and to extend the shelf to 16 slots you do need the expander card fitted with a +16 expander module so that you can manage both chassis and provide double bandwidth per slot (4 Meg per slot).
There are two types of DNIC cards, nl. 6 circuit and 12 circuit. This card must be fitted with a DSP module if you want to configure the ports for 128K. Only 26XX DTU’s will work with this card. This card and DTU’s has been discontinued.
The 27LC2 card is a 6 circuit card and only 27XX and 2751/2/3 DTU’s will work with this card. This card and DTU’s has been discontinued.
The replacement for this card is the 27LC3 card and 27XX and 2751/2/3 DTU’s will work on them.
The 3600 mux is a single shelf which can be extended to a dual shelf. Each slot using a expander+16 can deliver 4 Meg. If only a single shelf is used you can fit a +8 module on the control card to provide you with 8 slots and 4 meg per slot.
May 11, 2009 | Alcatel Newbridge MainStreet 3600...
Mainstreet 3600
I will send you the info on your mail address if you still need it.
Apr 25, 2009 | Alcatel Newbridge MainStreet 3600...
Can u tell me function of DSP , LGS CARDS IN 3600
LGS is same with FXS (Foreign eXchange Subscriber) card. It's voice card for serving voice needs with 2 wire connection. A analog phone connect to LGE on alcatel 3600 and other analog phone or PBX on remote alcatel 3600.
Look the others card e.g LGE (FXO) and E&M card.
DSP card processed the voice.
thanks
Feb 26, 2009 | Alcatel Newbridge MainStreet 3600...
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
Connect 3600 Alcatel over IP network
You can use some external TDMoverIP box to carry the E1's over an IP network
Apr 25, 2008 | Alcatel Newbridge MainStreet 3600...
Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
Apr 04, 2007 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
227 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
