Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech 500 gig usb plug in hard drive
The thing does not work. i plug it in and it tells me device can not start and it cant find drivers i really need help with this cus when i bought it, it started opening and pulling the warintee sticker off so now they wont take it back
  • tbeck54 Mar 06, 2008
    I have the same problem. The Ac power connection was lost and now the drive won't work? It's not being recognized. I try another computer luck.
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
Posted on Sep 06, 2008
  • 2,985 Answers
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Posted on Feb 13, 2008
When i plug my simpletech hitachi 320gb black cherry hard drive into my laptop the light comes on on the hard drive but my computer doesnt find it, went into device manager and it says the device wont...
i,m not a big fan of simple tech do to the fact that they sell cheap products and 9 times out of 10 they fail mechanically you can try and format to see if that works
Mar 23, 2011 | SimpleTech Signature Mini 320GB External...
I have a simpletech 500 gb external hard drive Model number is Simpletach model no- 96300-41001-071 Suddenly it stopped working When I go to Device manager I see yellow exclamation and when I click on...
Please make sure that the drive is properly plugged in and the drivers are properly installed. If you cant hear the HDD spinning, There is some serious problem and you must take it to an authorised service center. Opening the HDD on your own or by unauthorised people can lead to its damage. Also kindly try to check the same on other computers so that you can rule out the HDD failure ISsue.
Feb 22, 2011 | SimpleTech 500GB SimpleDrive Pro External...
Six month old Simpletech 500 GB ext. drive not recognized
I had the exact same problem. Solved by removing Simpletech drive from the 'flashy-box'. Unplugged drive from internals and threw the 'Pinnaferrina' case away and installed it on my motherboards extra sata plugin site (if it has one). If you open your computer case it should be labled on the Motherboeard as such. Mine has four. On the first attempt when I started the computer i Had no OS system showing on first boot-up. Shut off computer and power and shifted SATA (RED Cable) to another Sata plug on Motherboard and it booted right up and I had the drive back. You will need a longer Sata cable than the attached to the Simpletech drive and a power cable that matches the one on the Simletech . Forget looking for the drivers on the net and the Simpletech web site was no use.
Oct 10, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have a simpletech pininfarina 500 external hard-drive and cant find driver software online to install also doesnt recognise it
I have found a driver page of simpletech:
I believe that driver for your model is not available in the above link.
The drive would not be recognized when it is not compatible with your notebook hard disk.
I suggest you to contact simpletech for getting the drivers as they will have the hard disk drivers.
Jun 19, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech hard drive not found by my computer
This may or may not help, but it worked for me! After about 4 hours of trying everything (Device Manager/Uninstall, Disk Management, etc..) nothing at all would work. The USB external hard drive would power up but when you plug it in, the New Found Hardware will pop up and search unsuccessfully for drivers for a PLUG AND PLAY external drive!?!?!
In any event, I simply plugged another USB drive into my laptop (and desktop) and viola! The new hard drive was recognized and installed immediately as 'plug and play' should do. I then unplugged the new drive and tried plugging in the one that was recognized and all of the sudden....IT WORKS AGAIN!!!!
This fix might not help anyone who doesn't have a second USB external drive, but you could try plugging another USB device in and get it to load and then unplug it and try your drive. It worked for me on my laptop and then I did the same thing to my desktop (which also wouldn't recognize it) and it worked on the desktop too! Problem solved for me, thank GOD!
Hopefully, this bypass can save you a few hours of google time and unwanted anguish. Like I said, you may not have another USB drive but try plugging in any other USB device until it loads and then unplug it and then plug in your USB drive that wasn't working. It worked perfectly for me.
Hope it helps!!!!
Oct 02, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
PC cant detect my Simpletech 500gb hard drive can 'see' it on the my computer, right? welll, then perhaps you'll check the usb cable, no?
Apr 03, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
Simpletech pininfarina problem
It appears that this is happening a lot with external drives. Inside most of them is just a regular internal drive. In my case I simply removed the drive from the external enclosure (a SimpleTech 160 Gig) and installed it in my PC, where it works like a charm. Most people who have this problem go out and buy a replacement generic external drive enclosure for about $30.00.
Dec 05, 2007 | SimpleTech Pininfarina 80GB External USB...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
457 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
