Question about Sony Cyber-shot DSC-T900 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
Got a new 16gb memory card for my new camera the sony dsc-t900 it is not reading the card it says reinsert the memory stick and error code c:13:01 is showing tryed goin in the camera to format but nothing happens thanks
    New Friend:
  • 45 Answers
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Posted on Jan 25, 2010
    New Friend:
The camera show E:62:11
what does it mean?
Posted on Aug 16, 2010
4 Suggested Answers
SOURCE:
  • 17 Answers
SOURCE: Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
Posted on Nov 11, 2007
SOURCE: Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Posted on Jun 17, 2010
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Posted on Jul 05, 2010
How can I solve my sony cyber shot camera modal DSC W630 is shows error as C13:01
This error indicates a memory problem.
The camera can't read or write data to the memory card. Try turning off and on the camera again, or take out and reinsert the memory card several times. Also remove and reinsert the battery.
It also can mean the memory card is not formatted, or there is a format error for an other reason. Format the internal memory or the memory card.
It also could mean the memory card is damaged and can't be used any more. Then you have to place a new memory card.
I hope something will help.
This is also in you user manual.
Mar 19, 2014 | Sony Cyber-shot Dsc-w630 16.1mp Digital...
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
I need a manual for a sony camera dsc-t900
If you go to this web-site, you can download your manual.<br /> <br /> <a href="http://www.sony.co.uk/product/dsc-t-series/dsc-t900/tab/manual">http://www.sony.co.uk/product/dsc-t-series/dsc-t900/tab/manual</a>
Aug 24, 2010 | Cameras
Just bought a 16gb sony memory stick pro duo magicgate mark2 memory card for my sony t900 digital camera. pluging in the memory card it says reinsert card and a error code c:13:01 can u help
Hello. There several causes for this error code from bad card to bad camera. Some of the Chinese cards are counterfiet copys and could be a problem. Try rubbing the contacts on the card with a pencil eraser to clean them up. wipe with a clean cloth and try again. Try the card in someone elses camera to see if it works. Leave a message here if it still doesn't work , I'll look around some more.
builderdale
Jan 21, 2010 | Cameras
Hi My name is James
Hello
Thank you for using
FixYa for your problem
Your Memory Card is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. or just get a new card
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | Sony Cyber-shot DSC-T900 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony DSC-P10
C:13:01 error code means memory stick/ card is unformatted or broken memory stick/ card. please format memory stick/ card, this option is available in camera menu and try again.
If problem still there, use another memory stick/ card.
May 30, 2008 | Sony Cyber-Shot DSC-P10 Digital Camera
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot DSC-T900 Digital Camera Logo
1,208 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
