Question about Toshiba Satellite A105 Notebook
Trying to start from scratch
My Satellite was giving me all kinds of problems so I decided to reformat, although I quite certain  I did something wrong.   I pulled the hard drive form the pc and connected it to my desktop pc to reformat the drive.  Upon reinstallation of Satellite harddrive I have had no success getting even into the bios menu.  At first I was gettng  this error mssg:   NTDLR missing     ,my search instructed me to add certain files via usb or cd-rom boot.   This also with no success.  I then tried to paste those files to drive via connection to my desktop.  I now get    ...missing or corrupt:  \system32\hal.dll.     Please help!
  • Jaceunb Feb 13, 2008
    As soon as I turn on my pc I get NTLDR is missing Press Ctrl+Alt+Del to restart. the only F-key that works is F2 and it doesn't seem to have any options.
    Scholar:
  • 80 Answers
Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
  7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
    1. Type the following at the command prompt: X: (where X is the drive letter).
    2. At the prompt, type the following: ren boot.ini boot.in2
    3. Press Enter
    4. At the prompt, type the following: ren boot.bak boot.ini
    5. Press Enter
    6. At the prompt, type the following: exit
    7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
    If the above steps doesnt work then you will have to reinstall OS with the disks.
Posted on Feb 13, 2008
Soundbar doesn't pair with wireless subwoofer
It occurs to me that if the sub is no longer sending signals back to the unit then it won't find it. I am certain that it should be easy to have the sub repaired so that it does send out the signals.
Nov 14, 2015 | Audio Players & Recorders
Why doesnt the game works in the Xbox. It tells my that i have to clean the disk . I did clean it but it keeps telling me to clean it.
The Disk is scratched and you will need to get a new copy My cousin has had the same problem with one of his games and that's what the problem is hope this helps
Feb 14, 2011 | Microsoft Xbox 360 Console
Toshiba Satellite L3505D-S5938 Intermittant Keyboard Issue
Hi, This is beacuse of Virus/trojan that blocks the function o certain keys,
Try scanning your system with good antivirus, this would solve your problem permanently
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Dell Latitude D600 Notebook
Western Digital 1TB hard drive, worked all day, now giving me error, "reformat disk before using".. do I dare press yes?
Only if you want to lose all your data, if you just bought this earlier return it exchange for another one, this is kind of a bad sign of hard drive health. Did you bump it or drop it? if you cant or dont want to swap it out i'd suggest shutting down your computer and powering down the drive, then plugging it all back in and starting it up, you'd be amazed how often that fixes issues with new products. If you're ok with starting from scratch you can certainly reformat to attempt to fix a formatting issue but it will erase all data on the drive.
Hope that helps, Good luck
Jul 23, 2009 | Western Digital My Book Essential Edition...
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
WOULD LIKE TO REFORMAT MY Satellite A215 S7462 BUT DON'T HOW
Please try this. Load the first disk then power off. You can hold down F12 after power on then select the CD/DVD drive then hit ENTER. Windows will be loading files then always select the first one for each set of options. If you still have the same result, try tapping on C intead after power on. Hope this helps. Thanks.
Aug 24, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
1995 wind star decide to quit
disconect the batterie cables and scratch and clean very wheel even if they look ok and make sure any aftermarket alarm is disable and even if batterie looks good try to jump start the van
Jun 01, 2008 | 1995 Ford Windstar
The disc is unreadable
Is it just dusty, or are there scratches?
If it is just dust, clean is with something soft- t-shirts work quite well ni the abscence of anything else.Make sure to clean from the middle to the edges in lines, not circles.
For small scratches, a sometimes very useful solution is toothpaste.Put some toothpaste by the scratch and rub it it, then wash of excess toothpaste and dry the disc.The toothpaste fills in the scratch, leading to a temporary fix.
May 16, 2008 | Video Game Consoles & Games
Toshiba Satellite A105 Notebook Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
