Question about Whirlpool AWM6120 Front Load Washer
Washing machine door blocked
Hello I am unable to open the door at the end of a normal washing cycle. The door open button lights up but the door has been blocked for hours now. can you help me please?
  • sarithapc Feb 15, 2008
    Thanks Skeater I hadn't thought of trying that; it sounds like a good solution. I'll try that next time it (or anything else) happens.
Actually my problem got solved. I programmed a wash cycle again, and just before pressing the start button tried to open the door, and this time it came open without difficulty.
Posted on Feb 15, 2008
  • 20 Answers
Try to unplug the unit for 10 to 15 minunets, the washer may reset its self to default mode.
Posted on Feb 14, 2008
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Door lock on washing machine wont disengage
you could make a bypass switch, which interrupts the power to the door lock I would suggest a push button (press to open), so that it doesn't interrupt normal function(you can't accidentally leave it off), just attach the lead wire that would normally go to the lock mechanism to the button, then attach the return lead from the switch to the original circuit on the locking mechanism. then when you want to open the door (if it sticks again) you just press the button to break the circuit
Feb 01, 2016 | Indesit Washing Machines
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Zanussi Washing Machine - ZWF 14070W1 - Door Lock
If there is water still in the drum,try draining it out with the emergency drain hose down by the filter,then take out the filter bung by turning anti-clockwise and pull out to see what has got stuck in the pump.After this is cleared the door should open and the machine should be ready to run again.
Hope this helps.
May 25, 2010 | Zanussi ZWF14070 Front Load Washer
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Whirlpool AWM6120 Front Load Washer Logo
228 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
