Question about ATI RADEON® 9600 Pro, (256 MB) AGP Graphic Card
Monitor Image Partially Freeze and PC Stop working
I have a problem with my 4-year-old PC. Occasionally, I can boot up my PC and it can goes into the OS Windows XP. But now, after several minutes, the Monitor will display partial freeze image with abrupt coloring and the PC will hang (input not working anymore). Previously, it happens once in a while, but now it starts right after I turn on the PC.
I suspect it is the Video Card error as I have tried using my Friend's monitor and it still display the same symptom.
  • sentosagani Feb 13, 2008
    Well, One of the video card's fan stop turning as it is covered by dust.. I strongly suspect the video card, but i try to avoid the hassle if my video card is still alright =)
  • sentosagani Feb 14, 2008
    Thanks for the comment. I will vacuum once in a while in the future, provided I have bought vacuum cleaner too =).
    I have changed the video card and it works perfectly well now. Thanks ;)
  • 13,433 Answers
Hey, sounds like your videocard is about to fail. the only option now is to replace the card with another.
The card is damaged. Possibly overheating have you cleaned your pc recently? Might be full of dust and burned.
Posted on Feb 13, 2008
  • Ekse Feb 13, 2008
    I hope you cleaned it, vacuum cleaner can suck it all out, you can use it on fans also, just dont press hard or too long, let the fans spin and the dust will come off hopefully not in your face :-P
    good luck! :-)
  • Ekse Feb 13, 2008
    Please vote :)
I tested in my PC with the cables of my own monitor (Benq FP92Wa) and the image pop-up just fine, but after 5 seconds the monitor goes black. I tried to reboot in safe mode but the same thing happens
If the monitor has the same problem on two different computers, it is most likely the monitor has a problem. This monitor is probably about 9 years old, and it would probably cost more to fix it than to buy a new one.
Jul 20, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Msi cr620 i3-380m 3gb ram ( laptop freeze on battery use occassionally)
It could be a partially exhausted battery, giving a low supply voltage.
Feb 11, 2014 | MSI A6200-059US Laptop
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
http://pcdied.com/monitors.html#flashlighttest
manual.
https://www.manualslib.com/manual/30069/Hp-F1523.html#manual
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
My Acer Laptop screen fades or goes out when moved
Try reseating the video cable/connector. Also connect an external monitor to the external video port, power up the monitor first then boot up the laptop. The video image should automatically divert to the monitor, if you see a normal video image then the video card is OK and the problem most likely the LCD screen.
Jun 07, 2009 | Ace Computers Computers & Internet
No image on screen when boot up computer
check vga cable! check also video card on the pc!
Aug 16, 2007 | LG Flatron L1710S 17" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
ATI RADEON® 9600 Pro, (256 MB) AGP Graphic Card Logo
210 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
