Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
DC07 cutting out
I have a standard DC07 upright which after half an hours use cuts out out and will not start for a good forty five mins, all filters are clean and i suspect there is somewhere a thermal cut out switch. I was wondering if you can tell me where it is situated as im thinking of bypassing it until i purchase a replacement, I take it is possible for one of these switches to develop a fault or is it the motor ?
Many thanks
Shaun
  • 1 more comment
  • Anonymous Mar 03, 2008
    CUT OFF. EVERYTHING IS CLEAN. START SWITCH JUST BUMPS THE MOTOR ONE TIME AND THEN NOTHING....USED VAC APPROXIMATELY SIX TIMES.........HYSHERIF
  • Anonymous Mar 23, 2014
    suspect thermal cut-off or ??? Can I get parts and repair instructions
  • Anonymous Mar 29, 2014
    AFTER APPROX 4MINS THE BRUSH MOTOR STOPS AFTER RELEASING THE SIDE SWITCH AND ACTUATING AGAIN MOTOR TURNS FOR ABOUT 6 SEC,S AFTER A FURTHER 3 MINS THE WHOLE THING CUTS OUT.THIS IS THE SECONDVAC TO DO THIS BOTH BEING NEW.
  • 5 Answers
This may help!
http://www.fixya.com/support/t192124-overheating_dyson_dc07
Posted on Nov 22, 2008
  • 26 Answers
I sounds that your thermal fuse is cutting out. By no means try to bypass this thermal fuse. It protects your product from catching on fire. Replace the thermal fuse at a service center. How old is this product?
Okay,
Spurs21
Posted on Feb 14, 2008
Check all the filters first
WASH the side filters only
check for blockage in the inspection pipes
visit dyson.co.uk
and click on support you will see help videos there
Posted on Feb 29, 2008
My dyson DC07 is getting hot but NOT cutting out
Hi, it's Jack at Dyson.
It's normal for a vacuum cleaner's exhaust air and casing to become warm in use, due to the heat created by the motor when it's running. Dyson vacuums are equipped with a thermal cutout device, and this will shut the vacuum down if it starts to overheat.
It's worth checking your machine for blockages, and giving the pre-filter a wash - we recommend doing this at least once every 3-6 months as shown in the video attached. Use cold water without detergent, and allow at least 12 hours for both parts of the filter to dry completely before replacing them.
As long as your DC07 is picking up as normal and isn't making an unusual noise or smell in use, there shouldn't be an issue. But if you're concerned, you're welcome to reach out to our experts for further advice. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jun 05, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor cuts out after 5 mins on dyson vacuum
Hi Peter,
I'm sorry to hear about this. From what you've described, it sounds as if your machine may be overheating due to a blockage - the filter may also need a wash.
To locate and remove any blockages, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-SY-HEPA_US
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry somewhere warm before replacing it in the machine.
This should resolve the issue, but for any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Mar 18, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bypass thermal cut out
Hi Pam,
If your machine seems to be overheating and cutting out during use, this is likely to be due to a blockage - the filter may also need a wash. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve the issue, but if you're still concerned, please get in touch with us directly so we can provide some further advice. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Feb 10, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum will run for 5 minutes and shut off,
Your Dyson is designed to cut out if it becomes overheated, and it then takes about half an hour to cool down properly. If you don't resolve the problem, it will soon cutout again. Clogeed filters or other blockages are the usual cause of cutting out, but there are others, for example, incorrectly fitting valves, or broken belt. You need to do more cleaning. Follow the step by step instructions for your model, which can be found here.
http://www.dyson.co.uk/support/help.asp?article=51&product=DC07-ANIMAL
You will be following a path for solving cutting out when you are using the machine, and I would be surprised if you can't fix yours.
Jul 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
Mar 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dco7 quits running after 10 min I wait 15 min to start again
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dc07 cuts out
Hi!  This is the sign of a machine that is overheating, and almost certainly is caused by a partial blockage.  You need to check all the pipework and make sure the washable filter is clean (if you wash the filter, use only clean cold water, no detergent, and let it dry in a warm place for at least 12 hours, do not force-dry). I hope this helps.  I value your feedback, so please remember to rate this response. Good luck!
Feb 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Will be using my dc07 for about 10 mins then it cuts out i leave it to cool then it goes for about 5 mins and carries on like this
There is a thermal cutout on the motor causing this problem because it is overheating. Either it needs the filter replacing and a good blowout with compressed air or the thermal switch is faulty. Try replacing the filters first and if the problem persists it is probably a faulty thermal cutout. Dyson can either replace under warranty or an engineer will call and do a home refurb for a fixed price of £60
Jan 27, 2009 | Dyson DC07 All Floors Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
789 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
