SOURCE: hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
SOURCE: I have a century wirefeed 225 amp welder that goes
sounds like a component is over-heating, this would possibley be located on a power resistor attached to a large heat sink, try the set again, when it goes into high speed, detach the plug from the wall socket, taking extream care, gently touch the power resistors for high temperators, these normally run hot so the faulty one will be abnormally hot, be extreamly aware of the large capacitors, they will be fully charged and will give you an awfull belt.
SOURCE: My Century 130 Mig welder,
any 110 male end will work just make sure the plug is rated for 20 amps at least, 30 preferred
