Question about Refrigerators
Replacement compressor Hi, I have an Amana ATS5518SW fridge that appears to need a new compressor. We have had a refridgeration tech advise us that the replacement cost is around $800.00 for the parts alone. Any suggestions. Cheers Mark
  • 178 Answers
Yes here is one that is wayyyyyyyyyy less
300.00 for the part.
At they are the best. Way less
Just put your model number in and you can get it there.
I just looked it up for you
Thank you for your time.
Questions feel free to Call
Posted on Feb 13, 2008
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
My amana frost free refridgerator blowing warm
Can you hear the compressor running?
Mar 01, 2015 | Amana Refrigerators
How do I install compressor for amana refrigerator. Can a home handy man install a compressor? Do I need freon?
Hi.The compressor motor is connected to the refrigerant system, which is not user serviceable. It will be necessary to have the compressor serviced, or replaced by a qualified technician. During this process, the pressurized system will need to be re pressurized. This will require special tools, and regulative equipment, as well. This can be very dangerous, and that is why I prefer to give proper advise on this type of repair. Kindly, contact your nearest service tech.
Nov 26, 2009 | Amana ABB2223DEQ Bottom Freezer...
Refrigerator/freezer is not getting cold
If you are lucky, this could just need a new thermostat fitting.
If not, it could either be a faulty compressor, or a refridgerant gas leak!!!
The thermostat is not expensive, but the compressor is...VERY!
If your fridge/freezer is out of guarantee, I would replace the thermostat first. (These can be bought On-line from many sites, or try your local Depot), which of course will cost you more, but they will order the correct part if you supply them with the manufacturer & model number.
These details are usually found inside the fridge, either on one side of the lower panel behind the salad box or sometimes, on older models, may be on the rear of the fridge.
Nov 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Clicking sound, inside of the fridge is warm.
start by taking relay off compressor shake it if it sounds broken in pieces it is. if so go to parts house and get new and fix it yoself .u can do it. if that doesnt fix it it is a big piece of useless **** now .chunk it
Jul 02, 2008 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
My Whirlpool ARC7472 fridge freezer has stopped cooling both feezer and fridge. Removal of the cover in the freezer shows no ice build up, the fan runs, but no cooling effect in the chiller pipework to the...
it is low on refrigerant and has a sealed system leak without the proper leak detection equiptment and charging tools best left to the local ref tech
Apr 28, 2008 | Refrigerators
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
