Question about Canon FAXPHONE L80 Laser
Volume contraol on a Can Fax L290
We have a Canon L290 that we would like to turn the volume down on. I cannot find the onscreen menu and it does not have a handset... Can you help???
  • 15 Answers
Look in the User Settings Menu for volume control. You should find settings to set the volume lower, higher or off.
Posted on Feb 23, 2008
How to hard reset lg g2
1.Turn off the phone first.
2.Press the "volume down" button, while holding the power button down at the same time.
3.Hold them down until the android figure comes onscreen and/or the phone vibrates.
4.There should be a menu onscreen about now. From here you should use the volume up/down buttons to scroll through the menu of what you want to do. Select "Clear Storage" from the menu. This will set it back to the factory default. Oh, as you shouldn't be using the screen for this part, use the power button to confirm your selection. Hope this wasn't as clear as mud!
Jul 23, 2014 | LG Cell Phones
How can I turn the ringer down?
RINGER VOLUME SWITCH
Use a pen or other pointed object to
select the ring volume of the handset (HI, LO, or OFF).
If you need the manual to see a picture of where the volume switch is located on the handset, send me an email to LBrown18062@hotmail.com I will send the manual to you right away. Please put CANON FAX L80 as the subject. Lawrence Brown
Oct 22, 2011 | Canon FAXPHONE L80 Laser
I recently purchased a Canon PIXMA MX410 printer and was wondering if there was a way to turn the volume down when faxing? It is so loud. Thankyou.
Machine Settings
This section describes the items you can set or change in the Fax settings or Device settings menu available by pressing the Menu button.
For details on setting or changing, refer to the on-screen manual: Advanced Guide.
Sound control
Adjusts the volume of the audible tones, such as the keypad tone generated when pressing the buttons on the Operation Panel, the alarm emitted when there is an error, the offhook alarm that sounds when the handset is off hook, and the line monitor.
  • Sound control
    Selects the volume.
    • Keypad volume
      Selects the beep volume when pressing the buttons on the Operation Panel.
    • Alarm volume
      Selects the alarm volume.
    • Line monitor volume
      Selects the line monitor volume.
    • Offhook alarm
      Selects the alarm volume when the phone receiver is not put on the hook properly.
  • Here is the link to download the user guide as well:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx410#BrochuresAndManuals
    I hope this helps
    Thanks
    Please rate FIXYA
    May 25, 2011 | Office Equipment & Supplies
    SOMEONE TURNED OFF THE VOLUME WHEN SENDING A FAX, I WANT TO HEAR IT BEING SENT. HOW DO I TURN IT BACK ON
    Press 'Menu/Set' then press 1,4,1 and you turn the ring off or adjust the volume. Press Menu/Set then press Stop/Exit.
    Press 'Menu/Set' then press 1,4,2 to adjust the beeper volume. Press Menu/Set then press Stop/Exit.
    Press 'Menu/Set' then press 1,4,3 to adjust the machines one way speaker volume. Press Menu/Set then press Stop/Exit.
    Go to the Brother website and download the User's Guide for other information on the FAX-2820
    epags
    Feb 12, 2011 | Brother IntelliFax-2820 Laser Fax
    Volume on Canon Faxphone L170
    By pressing the menu button left of the LCD display,scroll to usersettings press ok.Scroll to volume settings press ok and change volume levels there.
    Dec 11, 2009 | Canon FAXPHONE L170 Plain Paper Laser
    Volume
    Press(menu),press arrow left untill (common Settings),Press (ok)Press left untill(volume Control) is shown.Press (ok).Choose the different volume control for the machine here.You can also choose to switch the volume completely off.
    Dec 08, 2008 | Canon FAXPHONE L170 Plain Paper Laser
    L170 Canon Fax Sound and volume control issues
    Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
    Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
    LOUD SOUND WHEN SENDING FAX
    There are 4 volume controls to access them press MENU.
    You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
    Now use the up & down arrows to get to
    Buzzer Volume = that the machine beeps
    SET
    Key volume = the tone that sounds when you press keys on the control pad
    SET
    Alarm volume = the alarm if something happens.
    SET
    Line volume = sets the level you hear at the fax is actively transferring a fax.
    If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
    The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
    Feb 12, 2008 | Canon L120 Fax Laser Printer
    Canon G3 fax machine
    Found it...Menu>Common settings>volume control
    Jan 14, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
    Canon FAXPHONE L80 Laser Logo
    102 people viewed this question
    old marine
    old marine
