Question about LG Prada KE850 Cellular Phone
Date I find the date changes to the previous day & when I change it a couple of hours later it changes back. I also keep changing the the auto update which I thought would fix the problem but also find it switches itself off. If you have any answers on how this can be fixed would appeciate any help. I bought the phone in early December 07. Have not really had any other faults with it since the new year except if over loaded is very slow to operate. thanks Annette
  • loveless_nob Feb 14, 2008
    Ever since the first of January 08, my phones been changing the date to the previous day on its own, and when i change it back and turn on auto update it turns itself and the date changes itself again. And because of this, i am unable to get the use off my alarm, and my calendar doesn't give off any alerts when i make any appointments. Ive had this phone since august 07 and this it the first problem i've had with it.( i think its the y2k bug, just 8 years late)
  • missmaggy May 24, 2008
    I have the same problem, which isn't very convenient as my phone is my primary alarm in the mornings and the date rollback means it doesn't go off. Any help?
I also had this problem. I changed the date to the next days date. It then changed back to the previous date (which was now the correct one) and so far it has stayed there... hope it works for you.
Posted on Jun 02, 2008
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
Mar 14, 2011 | Pantech Pursuit P9020
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 | Watches
I plugged in my Emerson Smartset Clock Radio (model CKS2005) and the date is off by a couple. Today is August 4, Thursday, and it states August 7, Saturday. How do I change the date? The date button is...
You have to run the clock back. Press Time/Date and then press up or down after you run it 24 hours the date will change, and the date will move day to day.
Aug 05, 2010 | Emerson Smartset Clock Radio
I nee to set the date. Is always back to the old date
mcdevito75 here, You may have a 2 position stem in your Timex, Slip a fingernail just under the crown and lift to it:'s first position, this should allow you to change the day / date without haveing to go thru the 24 hour cycle. Best Bet, change the date to the date before, then go thru the 24 hours to have the date change at midnite and not 12 noon. If the date keeps falling back to previous, the date wheel maybe loose in that case you can find a small watch repair shop inyour area, but it may be cheaper to replace the watch if this is the case.
Jul 02, 2010 | Timex 27191 Wristwatch
My Casio Edifice watch changes the day at 12:00 and not at 00:00 as it should. Can it be fixed?
If your watch is changing date before midnight (12 hours earlier as it should) - Pull out crown and turn watch hands clockwise for exactly 12 hours and push crown back. If it changes the date after midnight (12 hours later as it should) - Pull out crown and turn watch hands anti-clockwise for exactly 12 hours and push crown back. Don't do it from 00:00 till 04:00.
Jan 08, 2010 | Watches
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Date function notworking properly
Do as follows:
1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
Date keeps changing a week forward after setting time
A possible solution to this issue could be changing the automatic update of time and date. If it's currently switched on on your phone, try switching it off. And if it's already off try switching it off.
Here's where to find the setting: Menu >> Applications >> Clock >> Options >> Settings >> Automatic time update
For more info, check the (English) N79 manual on page 147
Feb 26, 2009 | Nokia N79 Cellular Phone
Setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
Jan 01, 2009 | Rolex Day-Date President 118238 Wristwatch
Mobile phones
yeah tht is a bit of a prob. one way to eliminate tht is by using the 24hr clock. having set it to 24hr mode i found eliminated the prob.
but again the phone does have a bug with the date changing back and lg needs to address it.
Feb 26, 2008 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
69 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
