Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-26D4U sound problem
I have the LC-26D4U Sharp Aquos model tv. Everything has worked fine for the 18 months or so that I've had it but now it seems as if something is internally wrong with the speaker connection. When the TV first turns on I hear a popping sound come from the right speaker. The first time this happened I turned the TV on and off a few times and the problem fixed itself. Since then, however, I hear that popping sound (just from the right speaker) and I get no sound. When the sound did work, both the left and right speaker worked fine and I still only heard the popping sound from the right speaker. I have tried different connections (HDMI, component, regular video/audio cables) and still nothing. It is certainly something internal that is the problem and I was wondering if you have heard of this problem before and know of a solution or advice. I am out of warranty and do not want to pay a few hundred if this is something I can easily fix myself.
Thanks for any help.
Same problem here with the popping sound and intermittent audio outages. Did anyone ever have luck with a solution? I know Gavin888, you said Time Warner was going to take a look at yours. What did they do to fix it?
Thanks very much!
  • 178 Answers
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Posted on Feb 13, 2008
3 Suggested Answers
SOURCE: Sharp Aquos LC-26D4U sound problem
i had the same problem lc26d4u. called sharp and they gave me a place to send it to . cost me 260.00 estimate to fix tv. have not heard from them since. but heard they may have sent the tv to the manufacturer. same sound board problem
Posted on Apr 02, 2008
Well, apparently this is a huge problem with many flat screen TV's. They surpress the volume output from all external sources (like DVD players) so you don't blow up their tiny speakers. They just expect you to add on a home theatre system to boost the volume their small speakers cannot handle. This is a real problem if you are in a boat or RV and do no have the space or electrical capacity to do this. I had the TV checked out and Sharpe said it met their factory standards so there was no help there. We have had to go with a small amp & speakers just to hear the TV & DVD movies etc. They need to put better quality speakers in these TVs. The video is awesome, now work on the audio guys!
Posted on Oct 20, 2008
Digital signal for my Sharp Aquos
Hi
On the TV menu did you change it from Cable to ANT?
Mar 13, 2010 | Televison & Video
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
Sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Aug 17, 2009 | Sharp LC-26D4U 26 in. LCD Television
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
You want me to tell you how I fixed it for free, but you don't want to help me for free. What's with that?
Aug 01, 2008 | Televison & Video
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
When I first bought my Sharp Aquos 42 inch TV...I started having sound problems...turned the volume way up to 60 maximum and could hardly hear it.
Then after the TV was on for 4 or 5 hours, there would be crackling chirping popping noise. It seems after the TV heats up for awhile...there is MAJOR sound problems.
So I was advised to buy a Sony surround system and connect it to my TV...deactivate the TV volume and use ONLY the surround sound. I did that...but the surround audio cables are connected to the back of the TV and I get the exact SAME problem with chirping and crackling sounds after the TV heats up.
SHARP IS NOT BEING HONEST WITH CUSTOMERS.
There should definitely be a RECALL on the sound board.
Replacing it does nothing....the overheating of the TV just damages the new sound board and the TV has to be repaired again and again.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
This unit has a chronic problem with the insulator material used on the heat sink on the ic's on the AV Bd. The unit must be disassembled and the AV bd. removed. The insulation on especially IC 2502 breaks down and must be cleaned off of the bd. and the ic and new insulator part # PSPAZA663WJKZ must be ordered and used as the insulator pad. If you send me an email to missiontracetv@msn.com I can send you the copy of the Sharp technical bulletin LCDTV-194.
Feb 26, 2008 | Sharp LC-26D4U 26 in. LCD Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
486 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
