Question about Akai LCT2662 Television
Tv is dead ,the power board is a mess(capacitors are bulged)
Need to find a replacement board or a place to have it repaired.
My tv won't turn on.
Posted on Feb 28, 2008
The tv worked normally for a couple of hours and then clicked off, like in standby mode. when i switched it off completely and turned it on again it worked again but only for a short time. now only get...
Now tv turn on,pictures it flashes only a couple sec. than died have sound left only?Yes,than the tv power supply board,that the board where the tv power a/c cord plug into it.Board it might have dying and dead components parts that are called capacitors.Take the tv aparts.Inspect and check the tv power supply board carefully for dying and soon to be dead capacitors parts,these capacitors parts are alway bulges up or puffing up onto it tops.U have all the tools and know basic electronic also can do basic soldering work too?Yes,replaced all these dying capacitors parts are bulges or puffing up on to it tops capacitors parts with the same Micro Ferit and those capacitors voltages like 5 or 10 voltages higher the old capacitors components parts u replacing,now will solved this problems,also capacitors will last longer and have more heat resistance than before.If the tv power supply board check out and have none dying capacitors components parts that are dying and soon to be dead are bulging or puffing up on to it tops.Than the tv have those 2 long boards each of it sides that are called LCD inverter boards are dead,these 2 long LCD inverter boards only job are to provided the tv LCD screen panel a backlight to produced pictures.If u can't repair the power supply board by ur self,if the tv power supply require it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refrubish power supply board or those 2 long LCD inverter boards for the replacement.
Jul 19, 2011 | JVC LT-42X579 42 in. LCD TV
My Toshhiba 53H71 went black and the red power light keeps blinking. Is it worth repairing.
You can repair it, it is repairable, the problem is power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will helpout in solving the problem....
Jun 15, 2011 | Toshiba 53H71 53 in. Rear Projection...
I have a Samsung LN52A650A LCD TV that 3 years old. Today when I go to turn it on it just clicks and does not turn on. The clicking wont stop...it clicks about once per second. I have to unplug the TV to...
The tv power supply board have dead components parts call capacitors most likely.U have all the tools and understanding basic electronic also can do basic soldering too?The tv power supply board that the board where the power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and dead capacitors parts.These capacitors parts are alway bulges up or puffing up on to it tops.Must replaced all these dying capacitors parts are bulging up ur puffing up on to it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
May 11, 2011 | Samsung LN52A650A LCD TV
Im getting no power whatsoever heard a pop last time i turned it on now nothing
The tv power supply board it is dead.That the board,where the power a/c cord plug into it.U have all the tools and understanding basic electronic also can do basic soldering work?Yes,take ur tv aparts.Check the whole power supply board carefully,by replacing all those blown capacitors that are busted open and all those capacitors are dying going to dead like bulging up or puffing up on to it tops.Replacing all those dead capacitors to a those new capcitors,do some modification of the capacitors parts like by replacing it in the same Micro fered,but the voltages should be 5 or 10 higher than those old busted or dying bulging up tops capacitors.By replacing all these dead capacitors and dying capacitors with a higher voltages capacitors.These capacitor to have a better chances to take more heat resistance,while tv be watching for hours of using.The tv should have power and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 08, 2011 | Sharp LC-42D64U 42 in. LCD HDTV
Samsung 32" LCD tv dead.
Please check the power supply of your TV including fuse and cables. Totally dead TV usually need simple things.
Regards
Jan 17, 2011 | Samsung Televison & Video
Hi I have a Westinhouse LTV-32w6 HD that doesn't turn on checked fuse at power board and it's fine any ideas ?
LCD tvs have power supply board problems very common are parts call capacitors are alway have leakages it bulges up on it tops or puffing up on it tops.These capacitors parts are dying about to be dead.That why,ur tv is not getting power,power light flashes,delay power on to tv like 2 to 5 mins or more.U know basic electronic and can do soldering?Check the power supply board for those dying about to be dead capacitors,that bulges up it tops or puffing up on it tops.Replaced these dying to dead capacitors,will fix ur tv power supply board problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replament.
Sep 18, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
My 18 months 32' sumsang lcd tv takes too long to come on.
Ur tv the power supply board,that the board,the a/c power cord that go into it.That the power supply board.That board have these parts call capacitors,the board they have these dead capacitors,it have leakage gases.These capacitors,they're bulges up on it top or puff up on it top.You know basic electronic's and soldering?Replaced these dead gases leakage capacitors,that are bulges up on top or puff up on it top.The power supply board will get back to nornal and come on quickly.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 25, 2010 | Samsung LN32A330 32 in. LCD TV
My samsung HP-T4254 keeps turning off in the middle of watching something and makes a clicking noise similar to the one it makes when you go to turn the tv on or off. This noise does not stop until I...
Ur tv power supply board have dead componnents parts call capacitors.Take ur tv aparts,the board that the a/c power cord go into it.That ur power supply board.Searches all around the power supply board and it supporting boards for these dead capacitors,they bulges up on it top,or puff up on it top.These capacitors parts that bulges up on it or puff up on it top must be replaced.U know basic electronic and how to solders?Replaced these dead bulges or puff up capacitors well get ur power back to normal and work.Or tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
May 17, 2010 | Samsung HP-T4254 42 in. Plasma Television
My tv dose not turn on
Try unplugging it from the wall, wait 1 minute, then replug.
I presume you have tried both the remote and the button on the front of the set.
Dec 11, 2007 | RCA F27242GY 27" TV
Akai LCT2662 Television Logo
49 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
