Question about Nokia 7373 Cellular Phone
Wet nokia 7373 !!
I used my nokia 7373 in the shower and i think i got water inside it iv tried taking the battery out and leaving it in dry areas this happened just over a week ago and now when i press select for the main menu the number 7 comes up instead and when i press the button that would end a call the number 2 comes up i cant get onto the main menu at all please help if u can
  • zumzi Apr 19, 2008
    well, my 7373 accidentally fell in a cup of coffee ( the keypad part only) 3 days ago, and now is kinda' working ( actually, it is really working, except the volume button). I had the same problem ( when pressing 7 it appeared 2, 9 was *, 0 was the volume, etc) but I thought it was beacause the coffee had sugar in it ( the keypad kinda' made a "crunch" noise) and needed a cleanup. Someone made it for me ( not a pro) but still ain't working well.
    How can I clean the volume button or get the keaypad off?
  • 92 Answers
This is ur keypad ic problem
please reball ur keypad ic
and u will get the solution
Posted on Feb 13, 2008
2005 Ford transit pickup.
do you have a remote control or is it in the key for door locks alarm?diconnect the battery for 10minutes and try to dry the areas affected by water a blow dryer will help get rid of moisture do it for as long as you need to then connect the cables then stick the key in the ignitionand just leave it there do not try to start for 5minutes then turn to on position and what the anti theft light if it still flashes rapidly your key might have a battery inside it and it went dead
Sep 01, 2017 | Ford Cars & Trucks
Tip
How to Save a Wet Cell Phone
Ever dropped your cell phone in the sink, or even worse... the toilet? Did you ever leave it in your pocket and run it through the washer? Did you ever swim with your cell phone in your pocket? It usually means you have to replace your phone, but sometimes if you're fast, you can save the phone! It's not being wet that kills a cell phone, it's being on and wet at the same time. This can short the circuitry out. If you're able to turn your phone off before it fries, you may well be able to resuscitate your drowned phone!
Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. Grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is wet and connected to a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
  1. Don't panic. Your phone will probably not be too damaged if you take it out of the water right away.
  2. 3Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
  3. 4Try putting your cell phone, with battery removed, in an oven on warm and hold. The dry heat will dry that ish out in no time.
  4. 5Remove the SIM card if you have a GSM carrier, . Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people, this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
  5. 6Dry your phone. You can put it in a bag of rice. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
  6. 7Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
  7. 8Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components and likely melt them, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes (however, unless the exposure to water was extremely short, it's not recommended to attempt to turn your phone on this soon). Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
  8. 9Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice. Turn the phone to a different position every hour until you go to sleep. This will allow any water left inside to run down and hopefully find an opening to escape.
  9. 10Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
  10. 11Test your phone. After you have waited a day or so, make sure everything is clean and looks dry, and re-attach the battery to the phone. Try turning it on. If your phone still does not work, try plugging it into its charger without the battery. If this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
  11. 12Take the phone apart if your phone doesn't turn on at all. If you feel comfortable doing this, try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work, go to the professionals.
on Jul 15, 2010 | Cell Phones
Tip
How to Fix a Wet Cell Phone
  • Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. So grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is merely wet and there is a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
  • Don't panic. Your phone will probably not be too damaged if you take it out of the water right away.
  • Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
  • If you have a GSM career, remove your SIM card. Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
  • Dry your phone. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
  • Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
  • Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes. Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
  • Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice.
  • Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
  • Test your phone. After you have waited a day or so, make sure everything is clean and dry looking and re-attach the battery to the phone and see if it works. If your phone does not work, try plugging it into its charger without the battery. If this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
  • Take the phone apart If your phone doesn't turn on at all. Try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work go to the professionals.
  • on Feb 17, 2010 | Cell Phones
    Water takes longer to drain from shower.
    A simple and safe way to unclog a shower drain is to use a wet/dry shop vac. Pop the grid strainer up with a screw driver, then shove the suction hose down the drain, then seal the hose with a wet rag. Turn on the wet vac, and you will feel slugs goe through the hose. Inside the wet vac you will find a hair ball.
    Nov 04, 2010 | Saniflo Home
    Water on my iphone
    1. Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. So grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is merely wet and there is a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
    2. Don't Panic. Your phone will probably not be too damaged if you right away take it out of the water. While it's in the water, immediately take it out.
    3. Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
    4. If you have a GSM carrier, remove your SIM card. Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
    5. Dry your phone. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
    6. Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
    7. Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes. Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
    8. Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice. It may be found under a brand name such as the "BHEESTIE Bag™" "DRY-ALL" "Damp Rid" or "Dry Right".
    9. Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
    10. Test your phone. After you have waited a day or so, make sure everything is clean and dry looking and re-attach the battery to the phone and see if it works. If your phone does not work, try plugging it into its charger without the battery, if this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
    11. Take the phone apart If your phone doesn't turn on at all. Try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work go to the professionals.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jun 15, 2009 | Apple iPhone Smartphone
    How to access keypad on Nokia 7373 to clean it
    Well the best solution right now would be to remove your battery. To remove the water, try putting your device in a bowl full of rice for a few hours. If that helps, great! Otherwise you'll need to take the device apart:
    http://www.sendspace.com/file/ue0gc9
    Try downloading that video =).
    May 21, 2009 | Nokia 7373 Cellular Phone
    Nokia 7373 Frozen screen!
    what is the imei number of the phone if you do not know you can take the battery out of the phone it is located to the back of the phone or you can press #06#
    Jun 22, 2008 | Nokia 7373 Cellular Phone
    Samsung A707
    well that means you have liquid damage and you have voided your warranty on your device. Your only option is to buy a new phone or take advantage of insurance if you have it!
    Mar 29, 2008 | Samsung SYNC SGH-A707 Cellular Phone
    Water damaged
    just follow some tips as i say...
    just take out the battery frm handset and keep in switch off situation and just dry wit hair drier by removing panels.. then try switching on... it may work...
    Feb 04, 2008 | Nokia 7373 Cellular Phone
    I accidentally washed my LG VX5300, please help.
    When electronics get wet, they MUST be taken apart as soon as possible and dried out. It probably has some wet areas inside that may have fried some connections. Water or corrosion by the water have short circuited something inside. There is still hope I hope to either take it apart and inspect and clean the corrosion off of all electronics or take it to an electronics shop and get them to do it.
    Nov 03, 2007 | LG VX5300 Cellular Phone
    Nokia 7373 Cellular Phone Logo
    69 people viewed this question
    Top Nokia Cell Phones Experts
    270rexton
    270rexton
