Question about Lexmark Z816 Color Inkjet Printer
My printing displays wrong ink levels and prints blank pages
My Lexmark Z816 printer keeps printing a blank page and the cartridge is almost full. How do I fix it?
  • 1 more comment
  • alilou85 Nov 21, 2008
    i have the same problem when the ink cartridge is empty and even if you refill it wont work due to the cartridge having a chip on it that the printer recognises and so even if you refill it will still show as empty and wont work.
  • Anonymous Mar 21, 2014
    does not print on a page but ink levels are correct
  • Anonymous Apr 01, 2014
    lexmark x5630
  • 60 Answers
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
Lexmark printer not dispensing ink
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Jan 08, 2013 | Lexmark Impact S305 - multifunction ...
Printing blank pages and pages with symbols on them
There are two main caused of blank printouts in inkjet printers:
Low ink level
Clogged nozzle of the ink cartridge
Refer to this article:
Blank Page while printing
Dec 18, 2012 | Oki Electric Industry C5900N Led Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X2550 ink cartridge refill
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Lexmark printer printing blank pages
hello sir,
dont worry this is d simplest case when either cartirage is choked or fileed with duplicate ink.
Try with another and if u still face this prob den reply
Jan 10, 2009 | Lexmark Office Equipment & Supplies
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
Dec 03, 2008 | Lexmark Z600 InkJet Printer
Printing Blank Pages
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
Nov 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark Z816 Color Inkjet Printer  Logo
238 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
