Fujitsu 36CS Air Conditioner
Problem for Fujitsu 36CS Air Conditioner
Regassing of fujitsu splitsystem airconditioner
By faulty on Feb 13, 2008
can the above aircon be regassed
Clarification Request
Posted by Master_Tech on Feb 13, 2008
yes
Best Solution
posted on Mar 16, 2008
Helpful)
ARBA
Rank: Master
Rating: 78%, 21 votes
All split ac can be regassed, but if it was only installed recently and the gas has leaked out then it will either be a manfactures warranty job, or if it was poorly installed it should fall under the warranty of the installer. most cheaper installers however only give a 3-6 month warranty on thier work if they give one at all. If it is uses either R410 or R22 gas (it will say on the outdoor unit) than any liscensed and i stress liscenced installer can fix the leak and regass it.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 36CS Air Conditioner
Questions and Unsolved Problems for Fujitsu 36CS Air Conditioner
Do you recommend Fujitsu 36CS Air Conditioner?
Answer
Answer
There was a wreck with a gas truck and a train about 4days ago and it mest up some power lines down... (More)
Answer
Our fujitsu invertor airconditoning unit is making a high pitched sound when operating. We had it... (More)
Answer
the timer light keeps flicking and the air con doesen't work ???
Answer
all the lights keep flashing on & off and absolutely nothing is happening when i try to turn the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 36CS Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
