Mitsubishi VS-60607 TV Logo
Posted on Jan 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a mitsubishi vs 60607 it will come on and everything seems to be working fine, however after about 30-45 minutes of watching tv it will shut itself off. what can i do to fix this problem?
Nick Novikov
Level 2:
  • Expert 101 Answers
  • Posted on Jan 29, 2010
Nick Novikov
Expert
Level 2:
Answers
101
Questions
Helped
22776
Points
165
Check loose connections on the power supl.board.
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Skyassoc
4answers
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
My VS-60607 won't turn on
unit will power on for a second then shut off. power supply ?
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
3helpful
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Won't turn on right
check your smps in your tv or Ic is collapsed
Mitsubishi VS 4543, Picture go out after a few minutes
I usually find that symptom you describe is caused by cracked solder joints on the power regulators or vertical output IC. I have also seen that symptom caused by loose solder joints on the vertical windings up inside one of the yokes. If you have experience in repairing TV's then you can disassemble the set and pull the main chassis, flip it over and resolder all of the parts mounted on heat sinks. If you do not have experience in repairing projection TV's then allow a qualified tech to handle it for you.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
