Clock radio I plugged my General Electric Model 7-4612B clock radio in while traveling Australia in a 220 V socket. I later found out my clock is only wired for 120 V usage and it no longer works. Is there an easy fix, or would it be cheaper to throw it in the garbage?
  • amin_e Jan 13, 2009
    that 120 V usage tricked somebody else also.
    there is no internal fuse ,the transformer indication are ~80v for the blue-white output and 1.07v for the red-black output. what parts other then the transformer could be damaged?
  • 2,130 Answers
Unless thate is an internal fuse it that blew, most likely it will be more expensive to repair than replace. The transformer primary winding is probably burned out. You have nothing to lose, take it apart and see if there is a fuse. If so, replace it with the EXACT same value as the original. If not, its not worth fixing.
You didn't say what the symptoms were, other than it didn't work anymore. I am assuming it is completely dead.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
General electric cb radio mod # 5811b has no power
You need a schematic of the radio to help with circuit tracing. Possible open speaker?
Mar 08, 2014 | GE Cb Radio General Electric 2 Way Radio...
The printer, without any interference, has ceased to function.
Welcome to fixya
I have a solution for this
Content
Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo
Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on.. Please respond if we have found a solution.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Samsung ML-2571N Laser Printer
My Panasonic TV/DVD/VCR Combination has a dull buzz sound on all channels. How can I stop that Dull Buzz? Model number PV-DM2719. LBV
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 17, 2011 | Panasonic Televison & Video
No color
Jan 15, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
I have the S1721 Travel Soother Radio Alarm Clock. It has stopped & a radio technician said it can't be fixed. It is THE best radio on the planet because it has a radio timer. I cannot find anything...
I came home and found a weird display showing 12 00 and ______f. Nothing worked, even when I unplugged it and took the batteries out. (I really, really like this clock radio so I wanted to find a solution).
I looked for a "reset" button and found one in the back inside the battery case (you have to remove the battery case cover). I took a pin and pressed it into the reset slot. I had to do this several times, turning it on/off and pressing several buttons and plugging, unplugging the clock/radio. It cycled through several times, then slowly the functions started to return, almost one function at a time. After several cycles of this, it turned itself back on and started working again!
Dec 01, 2010 | Sharper Image Travel Soother 20 Clock...
120 volt to 220 volt plug
it is sorry that the clock has been damged by high voltage so , it can not be repaired but you can replace the entire set
thank you
May 15, 2009 | Sony ICF-C318 AM/FM Clock Radio ( White )
Static occurs when movement in the room
This problem sound like you have had some damaged to the earth ground in your electrical wiring system. You should have a electrician thoroughly test the electrical outlets and wiring in your house or apartment. You should be very careful using any electronic equipment with a problem like this. Your Clock/Radio should be unplugged from the a/c wall socket and the internal battery removed. This will allow the microprocessor that controls all the Clock/Radios functions to reset. The Clock/Radio should be left unplugged for a period of a few hours to discharge the microprocessor. This will help the microprocessor to heal itself from the lightning strike. You will need to get the ceiling light fixed. There might be a shorted wire or something causing its failure. This could also be a burnt wire. Lightning power overloads can be very dangerous to all electric and electronic equipment. Try putting your clock Radio on a rubber mat to isolate it from any traveling static electricity that may be in the air. Try to discharge any static electricity that may have built up on your hands by discharging it on a piece of metal like a screw driver or metal surface.Do this each time before you try to use the clock/Radios button functions. This will stop further damage from occurring during you handling of the Clock/Radio. After discharging the microprocessor, reassemble the battery into the Clock/Radio and plug in the wall socket. The operation should return to normal. If not you may have more serious damage to the microprocessor. You can call the Emerson Customer support at this telephone number 1-800-898-9020. Give then the make and model number of your Clock/ Radio and ask them for assistance. I hope this information helps you with your problem.
Feb 09, 2009 | Emerson Smartset Clock Radio
A dead General Electric Model 7-4612B clock radio
The solution is to buy a new radio. Clock radios cost as little as $12 on Amazon.
Jan 22, 2009 | Audio Players & Recorders
AWR1-1W
It will Blow up :D Short out the transformer with some nice smoke out the back, its a very expensive machine and i wouldnt advise that.
Dec 02, 2007 | Bose Wave Radio
Open Questions:
396 people viewed this question
 Grubhead
Grubhead
