Question about HP Photosmart M517 Digital Camera
Camera will not power on
Have only used this one and not even owned for a year, camera has been sitting on base the entire time and will not power on. Tried replacing the batteries, removing the card, everything.
  • magnusdemuss Oct 13, 2008
    my cam just won't turn on same as yours
    Genius:
  • 2,985 Answers
If it has been on cradle most of the time there is a possibility the battery has overcharged'
I possibility because I don't know the tech., of this charge system.
As suggested back for warranty replacement is the best course
Posted on Feb 14, 2008
    Scholar:
  • 51 Answers
It is possible that the batteries have corroded the camera's battery contacts or worse. Using a bright light, if necessary, closely examine the contacts where the batteries connect. If there is any sign of corrosion use an eraser to clean the contacts. A regular pencil eraser should work if it is light corrosion. Do not store batteries in anything for long periods. Beyond that I would send it back/take it back before the warranty expires.
No power to contax 167mt even with new batteries
Do not use rechargeable batteries.
All batteries much be brand new. Some new batteries may have been sitting around for years can become defective.
May 17, 2012 | Contax 167 MT 35mm SLR Camera
It will not power on even when connected to power source, it has been sitting for 10 years. It is an 8mm. The was no problem when it was put away.
Hi
Normally it will be a battery problem. Try to replace the battery first. But wait connect the camera to power source and leave it for some time as a little juice in the battery will get charged and the camera will start working normally. You can replace the battery latter.
regards
Jul 14, 2011 | Cameras
When I switch the camera on,the lens rapidly unfolds out then rolls back in again, on the screen it says there is a lens error, this happens repeatedly rendering the camera useless, Is it...
The problem is with the lens assembly itself. The lens assembly sits within the body of the camera and can be replaced on its own without the need to replace the entire camera. While lens assembly repairs vary they usually range between 60 and 110 dollars. Consult your warranty to see if you are still covered by the manufacturer or the retailer as your repair would be free. Standard Canon warranties are 1 year from the date of purchase.
Mar 04, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
My D100 have not been used for 3 years and now there is no live signs,even whit full baterry
For a camera to sit for this length of time will require cleaning the battery contacts within the camera. Check to make sure the battery terminals are not corroded or the battery is leaking in any way The terminals in the camera may be cleaned using a good soft red rubber eraser on the end of a pencil. You can use a puffer to remove any rubber dust make sure these are shinny if corrosion is evident then a more aggressive approach needs to be made. if you don't feel comfortable doing this service/repair I would suggest taking the camera to a repair depot. however if you have a few items around home like the pencil you may be able to affix a small piece of sand paper to the pencil and clean the terminals gently. All this is only if the terminals are corroded (not shinny).
Going back to the battery, check make sure the battery is not leaking and after sitting for that long I'd suggest putting it back on the charger again and let is sit for about 20 minutes then take it out of the charger for 10 minutes and back in again this should give it the kick it needs to start the charge cycle.
I think what has happened the first time you charged the battery the charger couldn't "see" anything (absolute no power) and just went into standby mode. If the battery fails to take the charge you will have to purchase another battery. Once you have power the camera should work as it did before.
Jan 18, 2011 | Nikon D100 Digital Camera
Put new batteries it won't power on. been sitting not used for multiple years. bought new film but it doesn't seem to load since it won't power on. minolta qt si camera
Did it sit for years with batteries in it? You may need to clean corrosion off the battery contacts. Even alkalines and rechargeables can leak.
Oct 22, 2010 | Konica Minolta Maxxum QTsi with 35-80 lens...
I have bushnell sentry game camera need help reseting password
Put your camera On
Press "Enter" up to have a request for a 5 digit password
Enter 66214
ANd your camera go on !
Sep 24, 2010 | Bushnell Cameras
I am looking for my polaroid camera film. 600 plus
It's been out of production now for about two years. Any you do find will be past the expiry date, so you'll likely either find that the battery pack has insufficient power to last an entire film pack or that the film itself is "off" and has poor colours and that the emulsion does not get squeezed by the film rollers into the photo corners.
Any film packs you do find are likely to be expensive AND a total gamble. A company was recently reported to have announced plans to put the film packs back into production next year, but prices are likely to be at least £30 for just one (ten photo) film pack and I've heard nothing more since then.
What I did with my old Polaroid camera was to fit an external 6v battery pack of my own design to the camera. I then kept an eye out for old stock film packs which have been kept refrigerated; this meant that the batteries in the film packs were always flat but the photo chemistry itself remained fresh and fully usable. I'd post links showing you how I modified the camera, but lost interest a few months ago and sold the camera and photo packs to an enthusiastic photography student. It is a straightforward job though which simply involves opening the camera, soldering one wire to each of the two battery terminals and then running the wires out through the base of the camera to any suitable 6v battery pack. I used a slim LiPo battery left over from a dead digital camera.
Dec 21, 2009 | Polaroid Photography
Shutter button fell off Sony Cyber-shot DsC-W5 Camera
I bought a "for parts" dscw50 off ebay & unscrewed the side panels; this allowed me to remove the whole top panel (entire silver piece) & exhange it with the one on my own camera which I had broken the shutter button off of. Works fine now.
Jun 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
DSC-F828 Battery Latch
I suspect if you write a cordial note to Sony they just might fix it even though it is a few days out of warranty. I personally have had extremely good service from Sony (Sony Germany that is).
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
HP Photosmart M517 Digital Camera Logo
69 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
