Goodmans 26" LCD TV GTV26WLCD won't power on
TV fails to power up, standby light alternates green and amber
  • 4 more comments
  • mpelan Feb 18, 2008
    Thanks James, I got that far too. In a quiet environment you can hear a nasty "arcing" noise at about 1Hz in time with the LED flash, naturally coming from the area near the power connection. I'll open her up, power on, and stand back. The culprit will no doubt be winking at me, I just hope the whole board isn't fried now. If you're interested I'll post an update, I guess someone might be.
  • timnjue Oct 09, 2008
    i have the exact same problem with my gtv26wlcd i have found a power supply on a web site http://www.chsinteractive.co.uk/electric... hope this helps someone although it's not cheap but theese thing rarely are :(
  • matt j b Jan 04, 2009
    I've just bought the goodmans gtv26wlcd tv from a friend. The picture was absolutely fine at his place but as soon as I got it home the picture is really dark. Even when I turn the brightness/contrast up it still seems to be a really muddy picture. The really funny thing is when I press the teletext button the usual brightness comes back but only for a second before the teletext screen comes on - weird I know.
    Any ideas??
  • Anonymous Feb 22, 2009
    Hello...i have the same problem, i went on holiday for 2 weeks and went i got back the tv would not even power up!?!...can someone help??????????.....pleaseeeeeeeeeeeeeeeee....or is the tv ready for the bin? :o(
    Jo x
  • jo x Feb 22, 2009
    mmmmmmmm well...it just dose not do anything!...
  • Mike Papp May 15, 2013
    Hi, My friend bring his Tv, in similar problem. This is a power Supply failure. The all PCB was overheated, and burned out. The High Voltage is spark. I isolated, and change few parts, and maybe switch on. I left it, and cca. one hour later, switch off again, and not wanna start. I think the all module is worn, If I change one parts, the another will gone. I think scrap all. I check the upper link and "Sorry, this product is no longer available from us" :(
Its 111 ! I just worked it out on mine
Posted on Oct 20, 2010
Hi im having the same problem too with the same tv my warrenty has now run out if you find the problem can you let me no please!! thankyou
Posted on Oct 09, 2008
The problem lies with the power supply, my fault was with the 5volt output, which was closed circiut, to ground.
There is a kit for about £55, but i hear that these modules have a high fail rate. I did however find that the two output transistors were shorted also,
For a new module, sets back about £100+ (searching came back with one at £120 +PP,.
Is it worth it as a 26 LCD is roughly £150 new with warranty.
Posted on Jun 01, 2010
    Sergeant:
    Champion:
  • 362 Answers
Try unplugging it for a couple of minutes to reset the tv then plug it in and see if it comes on if not you probably have a power supply problem.
Posted on Feb 15, 2008
I have a 26 '' wide screen lcd tv by goodmans the standby light comes on but nothing else happens what could this problem be
hi there.most probably faulty capacitors on the power supply...most certainly if the issue has got slowly worse over time,to the point where the set will not come on at all..not an expensive repair if thats the case..
steve
Sep 13, 2010 | Goodmans Televison & Video
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Protron 26' t.v
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 30, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
Dec 19, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
BUSH IDLCD27TV006
http://www.chsinteractive.co.uk/pdf_data/KT02.pdf
Order Code….. KT02
POWER SUPPLY REPAIR KIT
BUSH MAXIM 1157 1154 Medion
Goodmans (Standard) 04TA069I 05TA71B 05TA071C
A standard power supply repair kit for faults attributed to the standby +5v rail.
BUSH IDLCD27TV006.
MAXIM 1154, 1157.
MEDION MD30112.
GOODMANS IDLCD27TV006.
The numbers off the boards will read: 04TA069I 26” 27” 30” 32”
& 05TA71B, 05TA071C.
LCD TV POWER SUPPLY PROFILO-TELRA.
Please check the primary of TR20 before fitting the kit.
Primary windings should read approx 2.700mH / 4.00 Ohm.
We recommend all kits are fitted by qualified engineers
We accept no responsibility for loss, injury or damage caused by your use of this kit as a successful repair
depends on your own skill and fault finding ability.
Circuit Reference
Loc Description
F300 T3.15A FUSE
IC21 FSD200
IC30 ICE1QS01
D315 12V ZENER
D318 2V4 ZENER
Q300 BC337
Q302 BC848C SMD
D325 1N4007
C213 33UF
C322 47UF
C356 47UF
C330 1000UF
LINK (IF NEEDED)
Oct 31, 2008 | Televison & Video
Goodmans 289NS standby light flashing amber no picture or sound
50% trouble of tv is lose connection so, try to re solder it but be care of short circuit
Sep 28, 2008 | Goodmans 289NS 14" TV
Televison & Video Logo
944 people viewed this question
Top Televison & Video Experts
Electro Med Services...
