Question about Jetway 939GT4-SLI-G Motherboard
7F debug code with no video output
I just transfered an AMD CPU, 2 gb RAM, and eVGA GeForce 8600GTS (256mb) video card onto my new Jetway 939GT4-SLI-G mobo.
Everything was working fine in the old setup, but the Jetway won't POST. There's no video on my monitor, and the debug code says 7F, which roughly translates to "POST error, see monitor for possible fixes." I cannot do that due to my lack of monitor output. Is there a way to save this?
  • dilpickies Feb 13, 2008
    No signal at all. The monitor power light flashes as it would if the PC were turned off.
    The monitor is a Samsung SyncMaster 753DF, which only supports VGA input. I am using a DVI to VGA adapter. I have used this monitor / adapter combo before with a GeForce 6200 without issues, but not the 8600GTS.
  • Anonymous Jul 11, 2008
    Have the exact same MB. Same problem. not the first time. Have replaced two boards with same issue. This time my fault. trying to overclock. system specs: 939GT4-SLI-G motherboard, AMD 4200+ cpu(dual core)
    OS-Vista Ulitmate 32bit. Antec 900 case,OCZ 600watt PS,2GB Kingston Hyper-X (KHX3500AK2/1G 2.6V 512X2, KHX3200AK2/1GR 2.6V 512X2=2GB) Two IBM 80gb Deskstar SATA Harddrives. one Floppy, one DVD RW drive. TWO XFX 8600gt 512mb vid cards in SLI
    Have tried reseating ram,removing CMOS battery,resetting cmos jumper,was getting 7F post code on LED, now getting famous FF code, NO Video,NO Beeps,NO NOTHING. All fans spin,All lights light, ran for six months no problems tried to overclock. changed settings in Vcore 7-shift mode, set CPU clock to230 system posted but hung at first bios screen. Restarted. Set system up again. Booted Windows error Vista could not start Please put in disk restart machine. System reset stopped dead! after that I get is 7F on LED's. will try letting in rest and try again. (Knew this board was fininky just had to try for more juice, not satified with 5.0 in vista) screwed now. lol hope some one has fix.
  • 22 Answers
Try cleaning the memory teminal with soft paper eraser.
Posted on Jun 10, 2010
Ok, other people have noted that sli slots come in 3, but sli requires two video cards to operate.
apparently, by shoving a card into one of these two "outer" sli slots the system bios automaticly starts SLI mode. and no matter what you do, you won't get video. unless of course you have SLI video cards and you have them in the appropriate slot.
The solution is simple.
yank all the video cards.. or 1. whatever. yank em all.
next. set the jumper to clear the bios, it's labeled "JBATT" and the instructions tell you "JBATT 2/3 clear cmos, and 1/2 for regular operation" or something like that.
Clear the bios.
once you boot it, while it's in "Clear cmos" mode, let it stay on for like 10 seconds and go to FF on the display.
shut it down and remove power or flip the switch on your power supply to totally shut off power to the system.
Change the jumper back to 1/2 for normal operation.
Place your card in the MIDDLE SLOT that's marked "single operation"
or if you have SLI, place them in slot 1 and 3 and connect them.
Boot the system with video cables attached, and everything will now boot as if you just initally purchased this motherboard, due to the bios being completly reset. even your time date will be reset.
This worked perfectly for me.
I will never buy jetway ever!!
Posted on Sep 28, 2008
Ok this from guest posted on July 11,2008 Not sure this will help anyone,but it seems to have "fixed" my problem.
1. I did all the normal(reseated cpu,took all ram out, cmos battery,re-set jumpers,disconnected hard drives(sata's) got nothing.
2.Put memory one stick at a time,into different memory slot.(got post with one stick in third slot).
3. Last thing that seems to gotten system to POST. Took out video cards.(remember I was running SLI. this board has three PCIe slots(middle one for single) oposite for Sli) like slot 1 and 3 for SLI. slot 2 for single card. WELL WHEN I MOVE ONE CARD INTO SLOT 2 SYSTEM POSTED AND THEN FINISHED BOOTING!! I feel in is the PCIe slots that are causing problem.
So if you only have one card. try placing that card in each slot. then into middle slot. it may clear SLI path allowing video signal too process. Sounds crazy but it worked for me. Or the God's of motherboard failures smiled on me this time.
Posted on Jul 11, 2008
  • 178 Answers
Do you see a bios screen at all or you just dont receive a signal at all?
Posted on Feb 13, 2008
I was wondering if my 939GT4SLI-G can run PCI Express 2.1 x16. Example of a video card would be, MSI R6950 Twin Frozr II OC Radeon HD. Thanks, Rob
This is your board:
http://www.dealtime.com/Jetway-JetWay-939GT4-SLI-G-Socket-939-NVIDIA-nForce4-SLI-ATX-AMD-Motherboard-Retail-939GT4-SLI-G-BRAND-NE/info?sb=1&tab=specs
This is the card you want:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575&nm_mc=OTC-RSS&cm_mmc=OTC-RSS-_-Desktop%20Graphics%20%2f%20Video%20Cards-_-MSI-_-N82E16814127575
Some say that the card will work but with limited capacity. I don't see the power requirements for the card but, I would guess a minimum of 350w or greater. Your board definatley was not designed for this card. It's alot of money for a card that may not work at all with your system.
This is MSI's link:
http://us.msi.com/index.php?func=prodvgaspec&maincat_no=130&cat2_no=&cat3_no=&prod_no=2093#menu
There is a "contact us" link at the bottom of the page where you can try to ask them but, in my opinion, for the money, I don't recommend the card without upgrading your system.
Dave
Jul 01, 2011 | Jetway 939GT4-SLI-G Motherboard
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
Need suggestion on PCI card for my PC.
Buy a ECS N9800GTE-512MX-F GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card it can be gotten at newegg.com for $89 it will handle anything you throw at it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134066
Oct 10, 2009 | Nvidia KFA2 GeForce 8600 GT Video Card -, ...
Adding 2 gigs memory
try to install windows xP!! when the screen turns blue!! just press f7 until the setup is finnish!!
Jul 12, 2009 | Jetway 939GT4-SLI-G Motherboard
Please help me to solve no display evga 680i sli (- -)error code
hi im josh in cebu phils.may i help you? friend try my solution ; Problem: Your Monitor Works, but Displays an Error Message Before Windows Loads If you see an error message, you at least know that video signals are getting to your monitor. Look for these common messages:
Bad or missing FILENAME In this message, the FILENAME refers to your video card's device driver file. Make sure that the driver has been copied to your hard disk and selected properly within Windows.
NUMBERxx This type of message (such as 24xx) indicates that you have a defective video card or a problem on the motherboard, or that you are trying to display in a mode that your system can't display. Check all the switch settings on your card and motherboard, and if the problem persists, see a repair technician. try to use that, good luck hope i helped you.
Mar 04, 2009 | Evga nForce 680i SLI (122CKNF68)...
Help
It will be ok if you are going to be sure that the ordering part# correspond to this table: http://products.amd.com/en-us/downloads/AMD_Opteron_First_Generation_Reference_100707.pdf
Your motherboard maximum Front System Bus is 1000MHz.
Aug 17, 2008 | Jetway 939GT4-SLI-G Motherboard
Playing CRISIS..
heres more info on the game
http://en.wikipedia.org/wiki/Crysis
Operating System - Windows XP or Windows Vista
CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
Recommended - 2 GB RAM
Hard Drive Space - 12 GB of free space
Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
Sound Hardware DirectX 9.0c compliant card
Jun 16, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
DRAM Beep
Try to clean the bronze circuit of your VGA card and insert it again, if its the same Your video card is broken, you need to replace..
1 Long beeps means theres an error on your vcard / or theres a problem on it..
3 short beep means thats your RAM have an error or a problem on it..
Once the if the mbord doesnt gives any sign or a beep and seems to be blackout there could be a short circuit on your mbord to the parts with a connection to it...
Feb 02, 2008 | Jetway 939GT4-SLI-G Motherboard
Sli 8600gts cards on mobo
maybe you need a higher wattage Power Supply. try decreasing the load like removing optical drives and extra HDD.
Sep 14, 2007 | Gigabyte GA-8N-SLI Motherboard
New Jetway 939GT4-SLI-G won't power up
Try using the onboard video first, remove the video card and any other card from the motherboard. If it still does this, then check the memory, maybe the speed is not compatible. If it's not that then try booting up with the old cpu.
Apr 21, 2007 | Jetway 939GT4-SLI-G Motherboard
Jetway 939GT4-SLI-G Motherboard Logo
1,337 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
