Question about Apple iMac 233Mhz/333Mhz Power Supply (Rev A) (p/n 661-2081) Power Supply
Air conditioning and heated rear screen
I have a 2001 Hyundai Accent. The air conditioning and the heated rear screen have suddenly stopped working. I have checked the fuses and they all seem fine. Any ideas please. Many thanks . Dippy!!!
    Problem Solver:
  • 13 Answers
What sounds to me that you have two difarent problems this could be an accident that they have stopped together.
You may check the Relays as described above first if you like.
For the aircon you must check that the aircon pump in the engine bay to see if the inner shaft is turning when the aircon is on .
This will determine if the switches and circuits in your car are functioning.
The best way to check the rear demistor is to have a volt meter and check you have 12 volts on the wires connecting to the Screen, if you do have 12 volts than your circuit on the screen is broken. If you don't than you have to start tracing your circuit from the switches to relays or to fuses back to screen using test lamp or volt meter.
Posted on Mar 13, 2008
  • 593 Answers
Sounds like a relay is out. These are devices that switch on high amperage accessories that a normal toggle switch would burn out trying to start due to the powerful amp draw. They are shaped like ice cubes in the fuse panel and pull out just like a plug. They should be labeled in the fuse box cover. Generic item that can be bought at the local parts store usually.
Posted on Feb 15, 2008
Where can I find the back brake adjustment wheel on a 2001 hyundai accent
look for a small slot in the top of the backing plate ( plugged up with a rubber block). Inside there will be small notched wheel that screws a threaded bar . Because of the conditions of the backing plate some manufacturers put the hole in the drum behind the wheel meaning the wheel has to be removed first.
Jul 27, 2014 | 2001 Hyundai Accent
Heard a belt break on my 1998 Hyundai Accent, but the engine didn't stop. What could it be?
you have torn an alternator, an air conditioning or power steering belt if equipped. check that the air conditioning works and gets cold if it used to and the power steering is not heavy if the car had it. if you broke an alternator belt your dash would be a christmas tree. if it had aircon and it doesnt work you need to look for your air con belt on the passenger side of the motor. if its not any of them something else has failed not applicable to any of them and it needs to be looked at asap.
Oct 10, 2012 | Hyundai Motor 1998 Accent
My 2001 Hyundai Accent 1.5 L, stalls out at stop signs and red lights. No codes are present, and check engine light does not come on, any ideas? Fuel pump?
See if your idle air control valve needs to be cleaned out. This is a common problem in cars that stall out a lot.
May 02, 2011 | 2001 Hyundai Accent
My 2001 hyundai accent has suddenly started to stall itself it can be running then just all of a sudden stall but it also can do this while driving along but would kick back in again while driving but its...
i think you need to go back to basics.if here is no obd fault codes in the system to give you a clue. then use a multimeter and have a good look at the wiring for corroded connectors etc. including the fuel pump?
Oct 13, 2017 | 2001 Hyundai Accent
2001 Accent, suddenly won't start
your model doesn't use an Inertia cut off switch for the fuel pump, chances are the fuel pump has just failed, they do that quite often.
Sep 04, 2009 | 2001 Hyundai Accent
Hyundai Accent SI-back windscreen wiper
there is a 15 amp fuse for the rear wiper under the bonnet check this, also i think the accent has a seperste switch in the dashboard for the rear wiper like th hyundai coupe.
Mar 24, 2009 | 2000 Hyundai Accent
2001 Honda Odyssey Ex Air Conditioning Not Cooling
Hi, my best advise is to have your air check for freon leaks ,low freon causes the compresor cluth to stop working ,this can cause the air to blow hot .......
Jul 10, 2008 | 2001 Honda Odyssey
Apple iMac 233Mhz/333Mhz Power Supply (Rev A) (p/n 661-2081) Power Supply Logo
127 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
